What is the adruino code programming for plant monitoring
what is the adruino code programming for plant monitoring
#include "thingProperties.h"
int moisturePin = A2;
/* Set this threshold accordingly to the resistance you used /
The easiest way to calibrate this value is to test the sensor in both dry and wet earth /
int threshold = 800;
Initialize serial and wait for port to open: /
This delay gives the chance to wait for a Serial Monitor without blocking if none is found /
delay(1500);
Defined in thingProperties.h /
initProperties();
Connect to Arduino Cloud /
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
moisture = get_average_moisture();
Serial.print("moisture ");
Serial.println(moisture);
assign the message variable based on water levels /
if (moisture > threshold) {
message = "Warning your plant needs water!"; /
Insert here your emergency message /
message = "Your plant has enough water!";
Serial.println(message);
int get_average_moisture() {
int tempValue = 0; /
variable to temporarily store moisture value /
make an average of 10 values to be more accurate /
for (int a = 0; a < 10; a++) {
tempValue += analogRead(moisturePin);
delay(100);
return tempValue / 10;
Since Message is READ_WRITE variable, onMessageChange() is
executed every time a new value is received from IoT Cloud.
void onMessageChange() {
Add your code here to act upon Message change */
int lightPin = A0; /*the analog pin the light sensor is connected to */
int tempPin = A1; /*the analog pin the TMP36's Vout (sense) pin is connected to /
delay(1500);
initProperties();
Maximum is 4
light = analogRead(lightPin); /
assign light variable to light sensor values /
Serial.print("light ");
Serial.println(light);
temperature = get_temperature(); /
assign temperature variable to temperature in Celsius */
Serial.print("temperature ");
Serial.println(temperature);
/* assign the message variable based on water levels /
delay(100);
float get_temperature() {
int reading = analogRead(tempPin);
float voltage = reading * 3.3;
voltage /= 1024.0;
float temperatureC = (voltage - 0.5) * 100 ; /*converting from 10 mv per degree with 500 mV offset /
Convert to Fahrenheit /
float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;
return temperatureC;
The Arduino Project Hub has a lot of plans for that task. Pick one.
Why did you not format your code and place it in a code block? You did not write this, but you gave no reference.
