What is the best way to connect Arduino to my phone?
Hi all,
I'm pretty new on that so I have some questions.
I'm gonna work on an Arduino project and want to see what is the best way to connect it with my phone without a router. I don't see a good way, all of them has the same user experience problems.
i.e. I create an Arduino project that uses a temp sensor and sends the info to an Android app on my phone.
Connections modes:
  • Bluetooth. . That way my app can send a request and Arduino can send the sensor readings. Is that going to block other Bluetooth connections? Let's say I connect my headphones via Bluetooth and also want to be connected to Arduino. They both use Bluetooth system so will that be a problem?
  • Arduino Wi-Fi AP mode. Arduino will run as an Access Point and my phone will connect to Arduino. Arduino will run a Web Server and will receive GET/POST request. It will respond with the temperature readings. The problem here is that user will lose the Internet connection as it is connected to that WiFi.
  • Arduino Wi-Fi station mode. My phone will be the Access Point and Arduino will connect to my phone. I guess I can also run a Web Server and do same that previous point. In that case, we have a bad user experience because it has to manually activate the WiFi AP in the phone
With all this in mind..should I ask in a different forum :slight_smile:
Seriously, now wit IoT that we connect a lot of devices to our phone or laptops.. don't we have a good solution. Most of that cases this is not a problem because devices have access to a router at home so that solves everything. But what do we do if we don't have a router?
Let me know your thoughts please
Thanks
alopsa21:
Very likely, but easily rectified.
The problem here is that user will lose the Internet connection as it is connected to that WiFi. ......
we have a bad user experience because it has to manually activate the WiFi..................
Yes - a phone forum. It seems to be where your problems lie.
Thanks you,
I did a quick test yesterday with Bluetooth and it worked so I think this is the bedroom optiin for Arduino "portable" projects.
However, WiFi would be a good option if your Arduino "lives" at home.
