What is the best way to control an electronic's switch with a digital pin?
Board: Arduino Uno
I'm trying to use the board to control a humidifier's on/off switch, depending on a DHT22's reading on humidity. Should be simple enough, then I realized I can't power the humidifier since it requires 5V and 300mA, which a digital pin can only provide like 5V 40mA.
So maybe I need to provide its power separately, what's a good way to do so? Do I have to buy anything else, like a controllable switch wired to digital pin?
who said ?
yes. it calls "transistor". invented in ~1950. but since then there are one special version of it "MOSFET". very helpful in digital circuits.
  • What is your definition of best way.
  • If you need to control the power to the sensor, use a P Channel MOSFET high side switch.
Atmel/Microchip says.
wow it is much more as i heard earlier: 20mA 5.5V
  • 40mA is the point where things can go wrong.
  • A safe maximum is 20mA.
Yes... that notice explains the depth... and thank you for posting it.
I think the safest way to run it for extended period of time is the best way.
Does that mean I also shouldn't power it with Uno's 5V output pin? I measured the humidifier drawing 5V 140mA at peak.
  • 150ma should be okay if running from USB power or 7 to 9V into the power jack.
Here's my current schematic sketch. Is that protection diode needed for flyback when switched off?
Hi, @k-h-c
Is that protection diode needed for flyback when switching off?
Yes, the magnetic field collapsing in the windings of the load, produces a reverse current that can damage the associated electronics.
The diode provides a short for the current around the MOSFET.
Tom.. :smiley: :+1: :coffee: :australia:
In this case, I'd have tended to put the protection diode across the load, that is the humidifier (R1 on the schematic). The mosfet has anyway a body diode in parallel with the "protection diode" the OP has drawn.
Oh. It looks like the whole thing is powered by a 9v battery!
It looks like this now. Protective diode across the load only. In this use case, humidifier shouldn't have any relay inside, so I guess it should be fine.
Hi @6v6gt,
Yeah it'll likely be powered either by a 9V cell or a AC-to-DC 9V adapter.
:+1: :+1: :+1: :+1: :+1:
Tom... :smiley: :+1: :coffee: :australia:
