What is the best way to do this project?
Hello guys,
How can I do this project?
I need to use this fan: https://www.arctic.de/en/P12-PWM-PST/ACFAN00170A
With an infrared sensor that can read temperature from about 15 cm. I found this:
https://protosupplies.com/product/gy-906-mlx90614-non-contact-precision-thermometer-module/
Everything needs to be battery powered.
Then I power on with a switch, an LCD should show the temperature and the fan starts, and a red led is lit.
When temperature is below certain degrees the fan should stop, the led should be green and a buzzer should sound.
What components do I need for this and what battery? I would prefer a rechargable powerbank if possible but I don’t know what specifications I need.
Thank you.
"Best" depends on your skills and budget.
You need any Arduino board for development. For the final build a Pro Mini or ATtiny should do, any standard LCD display, and a sufficiently strong battery.
This cab be done without any microcontroller.
How long do you require the device to run for on a single charge?
Not if he wants to use the MLX90614.
I would love that, but How? Because the temperature sensor must be infrared (to read temperature from a distance of 15 cm).
About 2 minutes.
Hi, @mongol
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
What are you checking the temperature of with a contactless thermometer?
Can you please tell us your electronics, programming, arduino, hardware experience?
Tom... :smiley: :+1: :coffee: :australia:
Is it possible to attach an infrared sensor to this relay?
This unit has what looks like a resistive thermistor input, it will not interface with your sensor module.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Thank you,
I have no experience, that’s why I search online in order to learn how to do it.
@mongol
I have deleted your new topic on the same subject and given you a break from the forum. Please familiarise yourself with the forum rules, which @TomGeorge linked to for you.
Thank you.
