I downloaded source for an ESP32 based drone flight controller, but don't quite understand the context of the bit shifting that is done throughout. I only ever use bitshifting on low-level hardware that can't support floating point and for things like serial packet deconstruction.
Can someone explain why that approach is used, and how its actually working?
Also, what is the deal with four reassignments of the same variable (GPOS, GPOC both do this) in a row with different shift values?
#include <Wire.h>
#include <WiFi.h>
#include <WiFiUdp.h>
#include <WebServer.h>
WebServer server(80);
char* SSID = "NetworkName";
char* SSIDPW = "NOPE"
WiFiUDP UDP;
char packet[7];
boolean recvState;
int ESCout_1, ESCout_2, ESCout_3, ESCout_4;
int input_PITCH = 50;
int input_ROLL = 50;
int input_YAW;
int input_THROTTLE = 1100;
int state1, state2, state3, state4;
float GPOS;
float GPOC;
int16_t gyro_x, gyro_y, gyro_z, acc_x, acc_y, acc_z, temperature, acc_total_vector;
float angle_pitch, angle_roll, angle_yaw;
boolean set_gyro_angles;
float angle_roll_acc, angle_pitch_acc;
float angle_pitch_output, angle_roll_output;
float elapsedTime;
long Time, timePrev, time2;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
float pitch_PID, roll_PID, yaw_PID;
float roll_error, roll_previous_error, pitch_error, pitch_previous_error, yaw_error;
float roll_pid_p, roll_pid_d, roll_pid_i, pitch_pid_p, pitch_pid_i, pitch_pid_d, yaw_pid_p, yaw_pid_i;
float roll_desired_angle, pitch_desired_angle, yaw_desired_angle;
double twoX_kp = 5;
double twoX_ki = 0.003;
double twoX_kd = 2;
double yaw_kp = 3;
double yaw_ki = 0.002;
pinMode(D5, OUTPUT); // Set Motor Pin 5 to Output Mode
pinMode(D6, OUTPUT); // Set Motor Pin 6 to Output Mode
pinMode(D7, OUTPUT); // Set Motor Pin 7 to Output Mode
pinMode(D8, OUTPUT); // Set Motor Pin 8 to Output Mode
delay(1300);
Serial.println("Connecting to ");
Serial.println(ssid);
WiFi.mode(WIFI_STA); // Connect to an AP
WiFi.begin(SSID, SSIDPW);
GPOS = (1 << 14);
GPOS = (1 << 12);
GPOS = (1 << 13);
GPOS = (1 << 15);
delayMicroseconds(1000);
GPOC = (1 << 14);
GPOC = (1 << 12);
GPOC = (1 << 13);
GPOC = (1 << 15);
yield();
Serial.println("");
Serial.println("WiFi connected..!");
Serial.print("Got IP: ");
UDP.begin(9999);
Wire.begin();
Wire.setClock(400000);
Wire.beginTransmission(0x68);
Wire.write(0x6B);
Wire.write(0x00);
Wire.endTransmission();
Wire.write(0x1C);
Wire.write(0x10);
Wire.write(0x1B);
Wire.write(0x08);
for (int cal_int = 0; cal_int < 2000; cal_int++) {
if (cal_int % 125 == 0) Serial.print(".");
Wire.write(0x3B);
Wire.requestFrom(0x68, 14);
while (Wire.available() < 14)
acc_x = Wire.read() << 8 | Wire.read();
acc_y = Wire.read() << 8 | Wire.read();
acc_z = Wire.read() << 8 | Wire.read();
temperature = Wire.read() << 8 | Wire.read();
gyro_x = Wire.read() << 8 | Wire.read();
gyro_y = Wire.read() << 8 | Wire.read();
gyro_z = Wire.read() << 8 | Wire.read();
gyro_x_cal += gyro_x;
gyro_y_cal += gyro_y;
gyro_z_cal += gyro_z;
GPOS = (1 << 14);
GPOS = (1 << 12);
GPOS = (1 << 13);
GPOS = (1 << 15);
GPOC = (1 << 14);
GPOC = (1 << 12);
GPOC = (1 << 13);
GPOC = (1 << 15);
yield();
gyro_x_cal /= 2000;
gyro_y_cal /= 2000;
gyro_z_cal /= 2000;
Time = micros();
GPOS = (1 << 14);
GPOS = (1 << 12);
GPOS = (1 << 13);
GPOS = (1 << 15);
timePrev = Time;
Time = micros();
elapsedTime = (float)(Time - timePrev) / (float)1000000;
Wire.write(0x3B);
while (Wire.available() < 14);
gyro_x -= gyro_x_cal;
gyro_y -= gyro_y_cal;
gyro_z -= gyro_z_cal;
angle_pitch += gyro_x * elapsedTime * 0.01526717557;
angle_roll += gyro_y * elapsedTime * 0.01526717557;
angle_yaw += gyro_z * elapsedTime * 0.01526717557;
angle_pitch += angle_roll * sin(gyro_z * 0.000001066);
angle_roll -= angle_pitch * sin(gyro_z * 0.000001066);
acc_total_vector = sqrt((acc_x * acc_x) + (acc_y * acc_y) + (acc_z * acc_z));
angle_pitch_acc = asin((float)acc_y / acc_total_vector) * 57.296;
angle_roll_acc = asin((float)acc_x / acc_total_vector) * -57.296;
angle_pitch_acc += 0;
angle_roll_acc += 0;
if (set_gyro_angles) {
angle_pitch = angle_pitch * 0.9996 + angle_pitch_acc * 0.0004;
angle_roll = angle_roll * 0.9996 + angle_roll_acc * 0.0004;
angle_pitch = angle_pitch_acc;
angle_roll = angle_roll_acc;
set_gyro_angles = true;
angle_pitch_output = angle_pitch_output * 0.9 + angle_pitch * 0.1;
angle_roll_output = angle_roll_output * 0.9 + angle_roll * 0.1;
roll_desired_angle = 3 * ((float)input_ROLL / (float)10 - (float)5);
pitch_desired_angle = 3 * ((float)input_PITCH / (float)10 - (float)5);
//yaw_desired_angle =0;
roll_error = angle_roll_output - roll_desired_angle;
pitch_error = angle_pitch_output - pitch_desired_angle;
yaw_error = angle_yaw - yaw_desired_angle;
roll_pid_p = twoX_kp * roll_error;
pitch_pid_p = twoX_kp * pitch_error;
yaw_pid_p = yaw_kp * yaw_error;
if (-3 < roll_error < 3) { roll_pid_i = roll_pid_i + (twoX_ki * roll_error); }
if (-3 < pitch_error < 3) { pitch_pid_i = pitch_pid_i + (twoX_ki * pitch_error); }
if (-3 < yaw_error < 3) { yaw_pid_i = yaw_pid_i + (yaw_ki * yaw_error); }
roll_pid_d = twoX_kd * ((roll_error - roll_previous_error) / elapsedTime);
pitch_pid_d = twoX_kd * ((pitch_error - pitch_previous_error) / elapsedTime);
roll_PID = roll_pid_p + roll_pid_i + roll_pid_d;
pitch_PID = pitch_pid_p + pitch_pid_i + pitch_pid_d;
yaw_PID = yaw_pid_p + yaw_pid_i;
if (roll_PID < -400) {
roll_PID = -400;
} else if (roll_PID > 400) {
roll_PID = 400;
if (pitch_PID < -400) {
pitch_PID = -400;
} else if (pitch_PID > 400) {
pitch_PID = 400;
if (yaw_PID < -400) {
yaw_PID = -400;
} else if (yaw_PID > 400) {
yaw_PID = 400;
ESCout_1 = input_THROTTLE - roll_PID - pitch_PID - yaw_PID;
ESCout_2 = input_THROTTLE + roll_PID - pitch_PID + yaw_PID;
ESCout_3 = input_THROTTLE + roll_PID + pitch_PID - yaw_PID;
ESCout_4 = input_THROTTLE - roll_PID + pitch_PID + yaw_PID;
if (ESCout_1 > 2000) ESCout_1 = 2000;
else if (ESCout_1 < 1100) ESCout_1 = 1100;
if (ESCout_2 > 2000) ESCout_2 = 2000;
else if (ESCout_2 < 1100) ESCout_2 = 1100;
if (ESCout_3 > 2000) ESCout_3 = 2000;
else if (ESCout_3 < 1100) ESCout_3 = 1100;
if (ESCout_4 > 2000) ESCout_4 = 2000;
else if (ESCout_4 < 1100) ESCout_4 = 1100;
roll_previous_error = roll_error;
pitch_previous_error = pitch_error;
while ((micros() - Time) < 1000);
state1 = 1;
state2 = 1;
state3 = 1;
state4 = 1;
while (state1 == 1 || state2 == 1 || state3 == 1 || state4 == 1) {
time2 = micros();
if ((time2 - Time) >= ESCout_1 && state1 == 1) {
GPOC = (1 << 14);
state1 = 0;
if ((time2 - Time) >= ESCout_2 && state2 == 1) {
GPOC = (1 << 12);
state2 = 0;
if ((time2 - Time) >= ESCout_3 && state3 == 1) {
GPOC = (1 << 13);
state3 = 0;
if ((time2 - Time) >= ESCout_4 && state4 == 1) {
GPOC = (1 << 15);
state4 = 0;
if (!recvState) {
int packetSize = UDP.parsePacket();
if (packetSize) {
int len = UDP.read(packet, 6);
packet[len] = '\0';
if (String(packet[0]) == "a") {
input_ROLL = int(packet[1]);
input_PITCH = int(packet[2]);
input_THROTTLE = 1000 + int(packet[3]);
input_YAW = int(packet[4]);
} else if (String(packet[0]) == "b") {
input_THROTTLE = 1000 + int(packet[3]) * 100 + int(packet[4]);
input_YAW = int(packet[5]);
if (String(packet[0]) == "1") {
twoX_kp = (float)int(packet[1]) / (float)100;
twoX_ki = (float)int(packet[2]) / (float)1000;
twoX_kd = (float)int(packet[3]) / (float)100;
} else if (String(packet[0]) == "2") {
twoX_kp = (float)(float)(int(packet[1]) * 100 + int(packet[2])) / (float)100;
twoX_ki = (float)(float)(int(packet[3]) * 100 + int(packet[4])) / (float)1000;
twoX_kd = (float)(float)(int(packet[5]) * 100 + int(packet[6])) / (float)100;
} else if (String(packet[0]) == "3") {
twoX_kp = (float)(int(packet[1]) * 100 + int(packet[2])) / (float)100;
twoX_ki = (float)int(packet[3]) / (float)1000;
twoX_kd = (float)int(packet[4]) / (float)100;
} else if (String(packet[0]) == "4") {
twoX_ki = (float)(int(packet[2]) * 100 + int(packet[3])) / (float)1000;
} else if (String(packet[0]) == "5") {
twoX_kd = (float)(int(packet[3]) * 100 + int(packet[4])) / (float)100;
} else if (String(packet[0]) == "6") {
twoX_ki = (float)(int(packet[3]) * 100 + int(packet[4])) / (float)1000;
twoX_kd = (float)int(packet[5]) / (float)100;
} else if (String(packet[0]) == "7") {
twoX_kd = (float)(int(packet[4]) * 100 + int(packet[5])) / (float)100;
} else if (String(packet[0]) == "8") {
Serial.print(input_ROLL);
Serial.print(" ");\
Serial.print(input_THROTTLE);
Serial.print(" ");
Serial.print(twoX_kp);
Serial.print(" ");
Serial.print(twoX_ki, 3);
Serial.print(" ");
Serial.print(twoX_kd);
} else if (recvState) {
UDP.beginPacket(UDP.remoteIP(), UDP.remotePort());
UDP.print(Time - timePrev);
UDP.endPacket();
recvState = !recvState;
Serial.print(angle_roll_output);
Serial.print(" ");
Serial.print(angle_pitch_output);
Serial.print(" | ");
Serial.print(roll_desired_angle);
Serial.print(" ");
Serial.print(pitch_desired_angle);
