I can't find any descent source for information about it.
I want my arduino to communicate with my pc by wifi (i have a router).
I have many (short) questions :
- What item should i buy for the arduino, I understand that the wifi shield is obsolete.
- where can i find a tutorial that will help me ?
- how the communication works, is it tcp ? or even http ? sockets ?
You could even use Bluetooth.
The question is about wifi, how to use wifi.
tautau123:
NO, that was not your question.
The original subject, let me refresh your memory, was What is the correct way communicate between arduino and pc wirelessly ?
Wirelessly is not exclusively wifi.
If that is your intent, then change your subject line!
Robin2
5
If you want to communicate using WiFi you need either a WiFi shield or the much cheaper ESP8266 module.
Or you could use an Arduino Yun that has WiFi as standard.
...R
