What is the diference between PM23AG and IRF520 ?
Hello everyone,
I have bought 2 boxes with electronics but I seriues don't know what all the things are.
Is there someone who can explain me what .. are
  • IRF520
  • LM340T12
  • MBR2045CT
  • SGP04N60
what is the diference between all this stuff ?
What can I make with this things ?
How do I use them ?
I hope someone can help me !!!
Thank so much
Marijn Crum
  • IRF520
  • LM340T12
  • MBR2045CT
  • SGP04N60
Google for the data sheet and read them.
Electronic things.
What can you make with paper? It is the same sort of nonsensical question.
Have you read the rules here?
How to use this forum
It will tell you how to ask a question.
You are looking at the lowest level parts you can get, the ones you list are a transistor, a huge diode, an IGBT, and a voltage regulator. They are all "power" parts, maybe to make a motor driver or a power supply. To figure out what to do you need to look at the data sheets and understand the basic principles of how these parts work. A book like Practical Electronics For Inventors 3rd Edition might help. I hope you got a good deal, it might be a little while until you know enough to really use these parts effectively.
http://www.vishay.com/docs/91017/91017.pdf
http://www.mouser.com/ds/2/405/lm340-n-405278.pdf
http://www.infineon.com/dgdl/Infineon-SGP_D04N60-DS-v02_02-en.pdf?fileId=db3a304323b87bc20123b894abf9001e
Hoi Marijn, welkom op het forum !
I guess you bought these at some flee market or garage sale.
As stated by the others before me, if you have to ask then you probably aren't into electronics yet.
The part you mentioned second, will probably the first you can and will put to use some time.
The other parts have a lot of uses, and you would need some experience to use them as meant to be.
If these were cheap, and you are planning to do a lot of electronics, you could store them somewhere and dig them up when you will need them.
There's a lot of parts you would need to learn about before you get to these parts.
You could also try to sell them on marktplaats/ebay, but that will be less fun.
