What is the difference between 4-bit and 8-bit operating mode in 16x2 LCD?
It would be helpful if somebody clarifies what the difference is. I have just started with Arduino and couldn't find any resources for this one.
Copy and paste your title in any search engine..!
4-bit mode needs less lines but more transfer commands and therefore more time.
Is the correct answer "another four output lines and a bit more time"?
8-bit mode is your classic parallel interface: every byte of data or command is sent across 8 wires. In 4-bit mode, each byte is split into two nibbles and sent in two times across 4 wires. The datasheet will tell you the whole story.
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
