What is the expected range for the Giga R1 WiFi antenna?
Hello,
First time trying to use the on board WiFi and I find no signal.
If I use my cellphone as hotspot, 30cm distance, I detect the signal but the result of WiFi.RSSI() gives me -90dBm.
Is there something I can do to boost the signal reception or is it the expected range?
Maybe I simply broke the antena during handling :frowning:
here is the example code I am using:
 This example  prints the board's MAC address, and
 scans for available WiFi networks using the GIGA R1 WiFi board.
 Every ten seconds, it scans again. It doesn't actually
 connect to any network, so no encryption scheme is specified.
 Circuit:
 * GIGA R1 WiFi
 created 13 July 2010
 by dlf (Metodo2 srl)
 modified 21 June 2012
 by Tom Igoe and Jaymes Dec
 modified 3 March 2023
 by Karl Söderby
#include <SPI.h>
#include <WiFi.h>
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  // print your MAC address:
  byte mac[6];
  WiFi.macAddress(mac);
  Serial.print("MAC: ");
  printMacAddress(mac);
  // scan for existing networks:
  Serial.println("Scanning available networks...");
  listNetworks();
  delay(10000);
void listNetworks() {
  // scan for nearby networks:
  Serial.println("** Scan Networks **");
  int numSsid = WiFi.scanNetworks();
  if (numSsid == -1) {
    Serial.println("Couldn't get a WiFi connection");
    while (true);
  // print the list of networks seen:
  Serial.print("number of available networks:");
  Serial.println(numSsid);
  // print the network number and name for each network found:
  for (int thisNet = 0; thisNet < numSsid; thisNet++) {
    Serial.print(thisNet);
    Serial.print(") ");
    Serial.print(WiFi.SSID(thisNet));
    Serial.print("\tSignal: ");
    Serial.print(WiFi.RSSI(thisNet));
    Serial.print(" dBm");
    Serial.print("\tEncryption: ");
    printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
  // read the encryption type and print out the name:
  switch (thisType) {
    case ENC_TYPE_WEP:
      Serial.println("WEP");
    case ENC_TYPE_TKIP:
      Serial.println("WPA");
    case ENC_TYPE_CCMP:
      Serial.println("WPA2");
    case ENC_TYPE_NONE:
      Serial.println("None");
    case ENC_TYPE_AUTO:
      Serial.println("Auto");
    case ENC_TYPE_UNKNOWN:
    default:
      Serial.println("Unknown");
void printMacAddress(byte mac[]) {
  for (int i = 5; i >= 0; i--) {
    if (mac[i] < 16) {
      Serial.print("0");
    Serial.print(mac[i], HEX);
    if (i > 0) {
      Serial.print(":");
Hi, can you share a clear picture of the board? And make sure that the antenna you received with the board is connected.
I tried with an other board and antenna pair and it's working fantasatic, like any normal wifi device. I tried swapping the antennas and it still worked so my problem is not the antenna as I first suspected, maybe the connector?
I took some pictures but the are not the greatest. I'm not really sure what to look for.
