What is the function of the tilde?
My current project contains this code
// send lighting pattern to matrix
void setLEDs(int row, int column, int interval)
	digitalWrite(latchPin, LOW);
	shiftOut(dataPin, clockPin, MSBFIRST, ~coordinateByte[column]);
	shiftOut(dataPin, clockPin, MSBFIRST, coordinateByte[row]);
	digitalWrite(latchPin, HIGH);
	delay(interval);
}  //  end setLEDs()
which is adapted from
Boxall, J. (2013) Arduino Workshop. San Francisco (CA) USA: No Starch Press. p. 143
coordinateByte[] is defined as
// define data to write to matrix
int coordinateByte[] = {0, 1, 2, 4, 8, 16, 32, 64, 128 };
What is the function of the tilde character ('~') in the code?
Thanks
Does it compile?
It looks like a typo error.
Tom... :o
Try looking up C operators on Google
Pete
el_supremo:
I had looked up C++ operators but found nothing. FTR: A search for C operators shows '~' to be a bitwise 'NOT' which is defined thus:
The bitwise NOT, or complement, is a unary operation that performs logical negation on each bit, forming the ones' complement of the given binary value. Bits that are 0 become 1, and those that are 1 become 0. For example:
NOT 0111 (decimal 7)
  • = 1000 (decimal 8)*
In this context, then, it matters not whether it is used or not. All it does is vary the bit patterns sent ro the matrix.
Thanks
vagulus:
so, if you send that.... does that mean that Neo isn't the One ?
vagulus:
If you'd looked in the Arduino language reference (top of the page under "Learning") you'd have found something very similar. Being rather new to all this myself I find that a rather useful starting point for understanding things in Arduino programs.
Steve
Isn't it also a C++ destructor?
cossoft:
Here's something it does:
Code snippet
	byte foo = 0;
	Serial.print("foo is ");
	Serial.println(foo, BIN);
	Serial.print("~foo is ");
	Serial.println(~foo, BIN);
Output
foo is 0
~foo is 11111111111111111111111111111111
How does tilde turn one byte into four bytes?
vagulus:
It doesn't.
There is no println for byte-sized values. The smallest integer size supported by println is long. The complemented value is sign extended to a long before the call to println.
