Hello does anyone know what the library is for the Porenta vision sheild Ethernet with Porenta H7. Or does it not require a library to work.
Thanks
Thanks
Hi @zm476. You can learn how to use Ethernet with the Portenta Vision Shield from this tutorial:
It does use a library named "Ethernet". This library is bundled with the "Arduino Mbed OS Portenta Boards" platform of the Portenta, so it is installed and updated along with that platform via the Boards Manager if you are using Arduino IDE, or pre-installed if you are using Arduino Cloud.
it worked thank you so much @ptillisch (Three times)
You are welcome. I'm glad if I was able to be of assistance.
Regards,
Per
