the code i have compiles fine, but i got a new laptop today fresh install of arduino with this weird new ide and all the sudden ime getting all these errors about some min call... anyone have any pointers?
In file included from c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\stl_algo.h:60,
from c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\functional:65,
from C:\Users\LocalAdmin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.0\libraries\Updater\src/Updater.h:25,
from C:\Users\LocalAdmin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.0\libraries\WiFi\src/BearSSLHelpers.h:27,
from C:\Users\LocalAdmin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.0\libraries\WiFi\src/WiFiClientSecureBearSSL.h:29,
from C:\Users\LocalAdmin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.0\libraries\WiFi\src/WiFiClientSecure.h:24,
from C:\Users\LocalAdmin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.0\libraries\WiFi\src/WiFi.h:11,
from D:\Arduino\Hypervisor_VisualMenuINTEGRATION\Hypervisor_VisualMenuINTEGRATION.ino:33:
c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\algorithmfwd.h:425:41: error: macro "min" passed 3 arguments, but takes just 2
425 | min(const _Tp&, const _Tp&, _Compare);
In file included from D:\Arduino\Hypervisor_VisualMenuINTEGRATION\Hypervisor_VisualMenuINTEGRATION.ino:31:
c:\Users\LocalAdmin\Documents\libraries\Streaming\src/Streaming.h:74: note: macro "min" defined here
74 | #define min(a,b) ((a)<(b)?(a):(b))
c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\algorithmfwd.h:453:30: error: macro "min" requires 2 arguments, but only 1 given
453 | min(initializer_list<_Tp>);
In file included from c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\stl_algo.h:66,
c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\uniform_int_dist.h:173:11: error: macro "min" requires 2 arguments, but only 1 given
173 | min() const
c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\uniform_int_dist.h:251:40: error: macro "min" requires 2 arguments, but only 1 given
251 | const __uctype __urngmin = __urng.min();
c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\uniform_int_dist.h:320:40: error: macro "min" requires 2 arguments, but only 1 given
320 | const __uctype __urngmin = __urng.min();
In file included from c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\functional:65,
c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\stl_algo.h:3473:34: error: macro "min" requires 2 arguments, but only 1 given
3473 | min(initializer_list<_Tp> __l)
c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\stl_algo.h:3776:57: error: macro "min" requires 2 arguments, but only 1 given
3776 | const __uc_type __urngrange = __g.max() - __g.min();
c:\users\localadmin\appdata\local\arduino15\packages\rp2040\tools\pqt-gcc\1.4.0-c-0196c06\arm-none-eabi\include\c++\10.3.0\bits\stl_algo.h:5815:57: error: macro "min" requires 2 arguments, but only 1 given
5815 | const __uc_type __urngrange = __g.max() - __g.min();
Multiple libraries were found for "SdFat.h"
Used: C:\Users\LocalAdmin\Documents\libraries\SdFat
Not used: C:\Users\LocalAdmin\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\2.6.0\libraries\ESP8266SdFat
exit status 1
Compilation error: exit status 1
