What is the method of connecting this piece with Arduino?
hello
This piece is used to measure frequency ,
Consisting of ic lm567
For more information on this piece visit this site
https://www.facebook.com/notes/indoware-elektronik/sound-activation-dengan-ic-lm567/743292299023388/
Pin Configuration
GND - GND
VCC - VCC, 3-12V, DC, use 5V directly is fine
OUT - output, when detect certain frequency output TTL low
FIN - Identifier frequency input, this can input the frequency for identifying, be aware the amplification should lower 0.2V
FOUT - Identifier frequency output pin, this pin output the identifying frequency which is set
ROUT - Amplifier real time output pin, detect audio amplifier signal real time output.
Does this module look for one frequency and then output a signal when that frequency is present ?
Thank you, I want frequencies directly from microphone to Arduino
I do not want any storage
So that I see all the incoming frequencies of the mike in (serial communication) in the Arduino and built it to be programmed according to frequencies because I have more than one frequency.
You have a false assumption. The device will detect the ONE frequency you have it set to detect. Only one frequency is detected at a time. Study This link for details.
You can program to detect any frequency in range, but only one after the other.
I hope this is really what you are looking for.
Paul
