This project is a black line following robot on a white background.I have been using this code and everything is working pretty well,but i found that my vehicle if moved out of the track is moving everywhre randomly i just wanted few modifications in this programme which can stop the vehicle if moved to white background and i want this vehicle to stop in a black box that is at the arena.It would be great if someone would guide me in this process.
This is the code i have used in the process.
// Number of sensors to use
#define IR 8
// Sensor factor
#define KS 1000
// Overlap factor
#define OL 200
// Base Speed Motors
#define SpBSE 140 //140
// Calibration Speed Motors
#define SpBSB 40 //40
// Break Speed Motors
#define SpFWD 140 //140
#define SpREV 190 //190
// PID constants
float Kp = 0.020; // 0.020;
float Ki = 0.001; // 0.001;
float Kd = 0.010; // 0.010;
long P=0, I=0, D=0, PIDv=0, pErr=0;
// Sensor Pins
const byte pSen[IR] = {21, 20, 19, 18, 17, 16, 15, 14};
// LEDs Pins
const byte pLED[3] = {4, 7, 8};
int SenX[IR];
int MinX[IR];
int MaxX[IR];
// Sensor Position
unsigned long PosX = 0;
unsigned long PosM = (IR*KS-KS)/2;
int PosH = 0;
// Detection Line
bool detLe = false;
// Running Status
bool OnRun = false;
// Time Counters
unsigned long Tm0 = 0;
unsigned long Tm1 = 0;
// Motor-A
int IN1 = 5;
int IN2 = 11;
// Motor-B
int IN3 = 10;
int IN4 = 6;
// Speed Motors
int SMoA = 0;
int SMoB = 0;
// Switch Pin
const byte pSW = 13;
void CalSnX(void);
void BlinkX(void);
void EstSnX(void);
void PosLED(void);
void CalPID(void);
void MoCTRL(int x);
void setup(){
// Only to sensors test
// Serial.begin(9600);
// Set all the motor control pins to outputs
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
// Motor A
digitalWrite(IN1, LOW);
digitalWrite(IN2, LOW);
// Motor B
digitalWrite(IN3, LOW);
digitalWrite(IN4, LOW);
// Start SW
pinMode(pSW, INPUT);
for(byte i=0;i<3;i++){
pinMode(pLED[i], OUTPUT);
digitalWrite(pLED[i], LOW);
delay(1500);
// Calibration Init
digitalWrite(pLED[1], HIGH);
CalSnX();
digitalWrite(pLED[1], LOW);
// Calibration End
void loop(){
if(digitalRead(pSW)) OnRun=true;
EstSnX();
PosLED();
CalPID();
MoCTRL(OnRun);
void CalSnX(){
Tm0 = millis();
Tm1 = Tm0;
unsigned long TmL;
for(byte i=0; i<IR; i++){
SenX[i]=analogRead(pSen[i]);
MinX[i]=SenX[i];
MaxX[i]=SenX[i];
while((millis()-Tm0)<=10000){
if(SenX[i]<MinX[i]) MinX[i]=SenX[i];
if(SenX[i]>MaxX[i]) MaxX[i]=SenX[i];
TmL = millis();
if ((TmL-Tm1)>=100){
BlinkX();
Tm1 = TmL;
analogWrite(IN2, SpBSB);
analogWrite(IN4, SpBSB+10);
void BlinkX(){
digitalWrite(pLED[i], !digitalRead(pLED[i]));
void EstSnX(){
detLe = false;
unsigned long avgS = 0;
unsigned int sumS = 0;
SenX[i] = analogRead(pSen[i]);
SenX[i] = map(SenX[i], MinX[i], MaxX[i], KS, 0);
SenX[i] = constrain(SenX[i], 0, KS);
if(SenX[i]>200)detLe = true;
if(SenX[i]>50){
avgS += (long)SenX[i]*(i*KS);
sumS += SenX[i];
if(detLe)PosX = avgS/sumS;
else if(PosX < PosM) PosX = 0;
else PosX = PosM*2;
PosH = PosX-PosM;
// Only to sensors test //
char DataX[100];
char sPosH[6];
sprintf(sPosH,"%5d", PosH);
sprintf(DataX,"%4d %4d %4d %4d %4d %4d %4d %4d %4d", SenX[0], SenX[1], SenX[2], SenX[3], SenX[4], SenX[5], SenX[6], SenX[7], PosX);
Serial.print(DataX);
Serial.println(sPosH);
void PosLED(){
unsigned long TmL = millis();
if((PosX>(PosM-KS/2))&&(PosX<(PosM+KS/2))) digitalWrite(pLED[1], HIGH);
else digitalWrite(pLED[1], LOW);
if(detLe){
if(PosX<(PosM-OL)) digitalWrite(pLED[0], HIGH);
else digitalWrite(pLED[0], LOW);
if(PosX>(PosM+OL)) digitalWrite(pLED[2], HIGH);
else digitalWrite(pLED[2], LOW);
else{
if((PosX<(PosM-OL))&&((TmL-Tm1)>100)){
digitalWrite(pLED[0], !digitalRead(pLED[0]));
Tm1 = TmL;
if((PosX>(PosM+OL))&&((TmL-Tm1)>100)){
digitalWrite(pLED[2], !digitalRead(pLED[2]));
Tm1 = TmL;
void CalPID(){
P = PosX - PosM;
I = P + pErr;
D = P - pErr;
PIDv = (Kp*P) + (Ki*I) + (Kd*D);
pErr = P;
void MoCTRL(int x){
int MoSpL = 0;
int MoSpR = 0;
if(detLe){
if(x){
MoSpL = SpBSE + PIDv;
MoSpR = SpBSE - PIDv;
MoSpL = constrain(MoSpL, 0, 255);
MoSpR = constrain(MoSpR, 0, 255);
// Motor A
analogWrite(IN1, 0);
analogWrite(IN2, MoSpL);
// Motor B
analogWrite(IN3, MoSpR);
analogWrite(IN4, 0);
else{
if(P<-OL){
MoSpL = -PIDv;
MoSpR = MoSpL;
// Motor A
analogWrite(IN1, MoSpL);
analogWrite(IN2, 0);
// Motor B
else if(P>OL){
MoSpL = PIDv;
MoSpR = MoSpL;
// Motor A
// Motor B
analogWrite(IN3, 0);
analogWrite(IN4, MoSpR);
else{
// Motor A
// Motor B
else{
if(P==-PosM){
MoSpL = SpFWD;
MoSpR = SpREV;
// Motor A
// Motor B
else if(P==PosM){
MoSpL = SpREV;
MoSpR = SpFWD;
// Motor A
// Motor B
It would be great if someone helps me in this process.PLease help me if you can as i have my competition the coming saturday.
