I want to be able to slowly pan a sensor and detect a person at about 100ft (~31m) or less.
I'm trying to find a sensor that is the optimum of 3 parameters:
lowest price
longest detection distance of a walking/standing person
fastest refresh rate
Sensors that I know of so far, and their issues:
MLX90614: The 5° FOV version has the best chance of being long range but the datasheet doesn't specify, or hint to, what the max detection distance of a person would be. the .65 sec refresh rate is also poor.
TMP006: can't work out detection distance/range
Panasonic Grid-Eye: only 5m detection distance/range
I do a lot of machine vision work. I want a sensor that is basically an individual pixel of a thermal camera. What makes an individual pixel of a thermal camera see farther than any of the sensors listed?
Nothing.. except the camera has X by Y pixels while the IR sensor (eg MLX90614) has one.
The Melexis will return an average temp based on the total radiation of its viewing sector.
Try the math: a 5 deg sector @ 30m? MANY sq feet. A single face is just a fraction ot that.
Temp. difference may be small, so it will very difficult to detect.
jremington:
Please define what you mean by "detect a human".
I'm looking for a sensor that is the optimum of the original parameters listed, that outputs a detectably different signal when it is pointed at a person that is up to 100ft away. Simple. It will most likely have some range in output values and through experimentation, I would find the range or threshold value indicating that a person, or a very very similar heat source (false target), is detected in its FOV.
As a few actual experiments will demonstrate, your expectations are completely unreasonable.
Since you are focused on thermal sensors, suppose the human is wearing well insulated clothing, or crawling on his/her knees with one or more dog companions, or standing still against a warm background. It is utterly impossible to solve the problem using only a single pixel.
To understand the problem, try using the Melexis sensor to detect a person just a few feet away.
jremington:
That's fine. I'm aware of the potential false targets. Considering every purchasable thermal sensor currently available, I'm looking for the one that represents the optimum of the parameters listed in the beginning of this thread. Doesn't have to be a single pixel, just has to be the optimum vs all other sensors.
You still have not defined the detection problem well enough to consider selecting a sensor.
Judging from what you have posted so far, you clearly haven't done enough experiments to understand the difficulty of the problem.
The question you should be researching at this stage is "is it possible to reliably detect a human at 30 meters, and if so, what are the methods, and their respective probabilities of failure and false alarms?"
jremington:
I disagree. Here's why: Pretend like you have every available thermal sensor on the market hooked up, each running independently, and pointed in the same direction. About 100ft away a person walks out from behind a tree, in the middle of all of the sensor's field of view (since they are all pointed in the same direction). While that is happening, you are logging the data from each sensor. Later you go through it and note the sensors which had a clear change in output data that correctly correlates with the point in time that the person became visible to the sensors. Now, of the smaller subset of sensors that were able to detect the person, sort them by lowest price, fastest refresh rate, and most noticeable data output change. Whatever that optimal sensor is, it will still be the optimal one regardless of whether a dog walks out from behind the tree, or a person with a thick coat walks out from behind the tree. It won't pick them up as easily, but it would still score better than the other sensors. Whatever that sensor is, it is the answer to my question.
The whole point of the question obviously is to get the opinion of someone who already has experience solving this problem, or a similar problem. Of course.
So what makes a sensor like the Panasonic Grid-Eye only have a 5m range while something like a thermal camera doesn't have that limitation? Are they using fundamentally different ways of detecting heat?
David82:
do the Math. with this sensor, at 5m, each pixel covers an area of 72cm x72cm. The sensor is spec'd to react to a 4C difference from background. So, Most Adult Males have a torso of 60cm x 60cm. So this Adult would cover 60% of a single pixel. if you increase the distance to 30m a single pixel now covers 433cm x 433cm so the adult's torso only covers 1.9% of a single pixel of the sensor. This 'signal' is thirty times too weak!
This thermal sensor reports an average temperature for each pixel. A single sub pixel area of hotter temperature is summed with all other sub pixel areas to create a value of temperature under that pixels view.
The only way a thermal camera could respond better is if it's 'optics' reduced (zoomed in) the area in question to increase it's resolution.
Right, so does it work using the same principles as light for a regular webcam? The way you are describing it strongly implies that as far as detection range goes, the principles are exactly the same as a regular camera. If that is the case, it is all very simple and I would just need to use a different lens SOMEHOW to zoom in and narrow the field of view. Using a different lens to narrow the field of view for a regular camera is simple. God only knows how and where you find the special lenses to do this on a thermal sensor! Is there a drop-off in the heat signal that a thermal sensor detects that behaves differently than light?
David82:
If your sensor measure heat, how do you stop the sensor from measuring the heat of the optic? Most infrared system actively cool their optics to remove this noise, Or, as the Gridview, it has no optics, just a minimal window.
I think you are going to run into the old "fast, cheap, or working" conundrum. You can only choose two of three, Either Fast and working? (very Expensive). Or, cheap and working (may take a lifetime to succeed).
"I want a sensor that is basically an individual pixel of a thermal camera."
If you want to "watch" an outdoor scene, beware the thermal image of, say, shadows of branches of a tree, moving (wind) on a dark surface. They regularly fool some simple PIRs I have driving my CCTV system.
In other news...
There were, long ago, some (to me) exciting threads about using the sensor in the then-recently-released "Wii-mote"... an accessory for the Wii entertainment center.
The sensor had a small.... 128x 128? something like that... sensor, but the cool thing was the output from the sensor: X-Y coordinates of the 5 brightest IR signals in the sensor's field of view.
Why didn't this sensor become available as a component?? (You had to buy a Wii-mote and tear it apart.) Why didn't this device become popular with hobbyists? (Or maybe it did x 1 or even x2?!)
(The following search string pulls up Google Good Stuff: "wiimote ir sensor hacks")
