what is the packaging (full part number of this....)
of this part http://www.digikey.co.il/product-search/en?x=0&y=0&lang=en&site=il&KeyWords=ctx1085-nd
for a schematic on OrCAD CIS i need to know the full name of this part ATS16B+Packaging type (footprint)????
It's an ATS16B. That's it.
There is also a -E version.
You realize that for designing board with these, you can just use the library for any crystal in that package (that's by far the most common package for crystals, especially cheap ones)
It’s a HC49 package.
The /us tells you that it is a smaller (flatter) housing, but that doesn’t do anything for the footprint.
The site you found it, tells all about it:
Description Crystal 16.0000MHz 30ppm 18pF 40 Ohm -20°C - 70°C Through Hole HC49/US
MAS3: It's a HC49 package. The /us tells you that it is a smaller (flatter) housing, but that doesn't do anything for the footprint.
i expected it to be something like TH2... ie something with TH (Through Hole) and a number that indicate the number of pins what is the meaning of HC?
KobiAflalo: what is the meaning of HC?
Things aren't always straightforward. In this case (HA!) though, it's just the military way of doing things that's come into play. HC is "Holder, crystal".
