What is the power consumption of the Arduino UNO Q?
I'm posting this in the “3rd Party Boards” subcategory because I don't have permission to post this in the correct subcategory.
According to the “From Blink to Think” livestream, the Arduino UNO Q consumes one watt of power. On the other hand, https://docs.arduino.cc/tutorials/uno-q/power-specification/#input-power recommends a USB-C power supply with an output of at least 15 watts. Which power consumption metric is more accurate?
I have moved the topic
What I saw was 5V at 3A so max 15W. I believe the Pi 5 is 5V at 5A or 25W so very competitive.
I have corrected the problem with the configuration of the UNO Family > UNO Q category that caused that. The category is now configured so that everyone can create topics in it.
I apologize for any inconvenience.
The confusing part is that although a 25 watt USB-C power supply is recommended for the Raspberry Pi 5, it itself only consumes four watts. At least according to the “Typical bare-board active current consumption” column of https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#typical-power-requirements.
The specs are always for the worst case. They even had to invent their own special USB-C interface to get from 3A to 5A. The worst case is when the radio is at max.
Would you design a PSU that only worked at less than the worst case?
Worst case for RPi is when you have an 16GB version with a bunch of powered USB devices connected, an SSD, a camera, and are using the Ethernet. Use of the GPU is probably another factor.
I'd expect the Wifi to be relatively minor (250mA for wifi modules is pretty common, whereas a USB device might draw 500mA or more.)
Have you read the note and the paragraphs following the table you linked?
It explains why they recommend a 25W power supply.
Here is the datasheet.
https://docs.arduino.cc/resources/datasheets/ABX00162-datasheet.pdf
EDIT: After doing research it is really different to a UNO R3 and you should check the datasheet.
I am fairly certain that is the answer the company president gave when asked why 25W at the Pi5 launch.
Not really:
From the datasheet
here’s a complete article on the power specs
I linked to that same article in my original post. It's lacking these details:
The only power consumption metric that both articles provide is recommendations for the rated current capabilities, when shopping for a 5V USB-C power supply. Only after including a statement made during the “From Blink to Think” livestream, does the discrepancy between vendors become somewhat resolved.
Specifically here: https://youtu.be/uYb8YzdMWbc?t=3722s
All of [the Qualcomm Dragonwing QRB2210’s capabilities] is in one watt of power envelope.
Some of my power testing here: Arduino Uno Q · Issue #83 · geerlingguy/sbc-reviews · GitHub
In summary:
  • Idle power draw (at wall): 0.5 W
  • Maximum simulated power draw (stress-ng --matrix 0): 1.9 W
  • During Geekbench multicore benchmark: 2.5 W
  • During top500 HPL benchmark: 3.5 W
These measurements were all taken with a 27W USB-C power supply plugged into a ThirdReality Smart Outlet, with WiFi on and accessing the Uno via WiFi. No other peripherals were plugged in at the time.
Hi, I've been measuring power consumtion with a usbc meter, because I'm very interested in both consumption and heat generation. I can confirm more or less the same numbers. I've a feeling that HW drivers are still not really optimized though, so maybe in some tasks it will hopefully improve in the future (decoding and encoding video as an example)
What about needed Boot Wattage ?
Can you Boot & Run at 0.5A / 1A / 1.5A / or ?
I run Uno Q, webcam, dongle, 2 servos and proximity sensor, everything on usb-c cable connected to Xiaomi powerbank (10000 mAh), and it can last for full day, sometimes 2 days on one charge. You need normal 3A cable to dongle for sure, otherwise 2 servos on full speed will reboot Uno. Project here: GitHub - msveshnikov/agi-robot
For some reason, it works stable only with USB-C/USB-C cable between powerbank and dongle. USB/A in powerbank booting Uno in 50% probability, it is not coming to heart animation just rebooting again after logo
I wonder how hot the mpu gets during that top500 HPL benchmark?
It is extremely hot, you can't touch it
