I am having some doubts that I did mount/unmount of SD card correctly. I often get errors when using Sd cards on adafruit data logger shield, such as not able to begin.
I suspect that just inserting the SD card and pulling it out is not the proper procedure.
Before I can unmount an SD card, do I need to call any function to stop it?
If I insert the card again, do I need to start it before reading from it?
If I have opened a file to write on the SD card and then remove the SD card, when I insert the card again, will I be able to just continue to write on the same file or do I need to reopen it?
I wish someone has answered my question about the whereabout of the SD library manual.
You need to close any open files.
No. The device has no way of knowing that the card has been inserted/removed.
Neither. Removing the card without closing the file corrupted it.
There are a number of variations of "the SD library". You weren't specific enough.
In any case, nothing that the library does differs in any radical way from reading/writing files on a PC, except that the media is removable.
