What is this and what this do
i want to know what is this and what is the purpose
thank you
Can you show photos of the back side?
Also a really close up to the chip (the black rectangle with 8 legs) so that the writing on it can be seen?
MCP6002 | Microchip Technology
Follow this link for a complete description of this General Purpose Op-amp: MCP6002T Datasheet PDF , Microchip : 1 MHz Bandwidth Low Power Op Amp
According the Aliexpress seller it is a body seat detection conversion module
in other words can we say that it can be used for detecting vehicles on surface ?
If you use it with this pressure sensor array, it will detect anyone sitting on it.
No, you cannot detect vehicles with it.
It is what is used in car seats to know if someone is seated so the cars system can check if they have their seatbelt on.
Tom.. :smiley: :+1: :coffee: :australia:
What vehicles? What surface?
I think the board can have many uses. For example it could be connected to a light dependant resistor or a thermistor or a soil moisture sensor. The "amplification" control can be adjusted so that the analog output varies between 0 and Vcc for a suitable range of conditions. The "comparison" control can be adjusted to control when the digital output changes from high to low.
The chip is a dual operational amplifier (op-amp). One op-amp amplifies the signal from the sensor for the analog output. The other op-amp is used as a comparator to control the digital output.
