What is this error message and why am I getting it?
C:\Users\203310\AppData\Local\Temp\ccakTOvO.ltrans0.ltrans.o: In function main': C:\Users\203310\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/main.cpp:46: undefined reference to loop'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
I keep getting this error message when trying to upload to a (genuine) Uno.
Here is my code:
`#include <Servo.h>`
`Servo myservo;  // create servo object to control a servo`
`void setup() {`
  `myservo.attach(9);  // attaches the servo on pin 9 to the servo object`
  `delay(100);`
  `myservo.write(0);                  // sets the servo position`
  `delay(100);                           // waits for the servo to get there`
  `myservo.write(90);                  // sets the servo position`
  `delay(5000);                           // waits for the servo to get there`
I hope I formatted the code correctly.
Thanks.
you did not but nice attempt :slight_smile:
and if it's all the code then you are missing some stuff like the closing brace and the loop() function definition
this would compile
#include <Servo.h>
void loop() {}
(read How to get the best out of this forum to see how to use the code tags and more)
You do not have a loop() function in your sketch. Such a function is mandatory in an Arduino sketch even if the function does nothing
Your topic has been moved to a more suitable location on the forum.
