what is this instruction will do in code |=(1<<x)
hi, I have got a an example code for reading ADC values from arduino uno board on ADC5 pin
I would like to know that what “logical or equals” do in this ADCSRA |=(1<<ADSC);
what is the difference in =(1<<x) and |=(1<<x) ?
int A=0;
 Serial.begin(19200);
Setup_ADC();
A = ADC;
Serial.println(A);
void Setup_ADC()
  ADMUX   =  (1<<REFS0)| (1<<MUX0) | (1<<MUX2);                             // Avcc(5v) ref voltage and ADC5 selection
  ADCSRA  =  (1<<ADEN) | (1<<ADIE) | (1<<ADPS0) | (1<<ADPS1) | (1<<ADPS2);  // enable adc, start conversion, pre-scalar 128
  DIDR0   |= (1<<ADC5D);                                                    // disabling ADC5 as a digital input
  Start_Conversion();
void Start_Conversion()
  ADCSRA |= (1<<ADSC);  // Start the ADC conversation
ISR(ADC_vect)
  A = ADC;
  Start_Conversion();
have you read the guide on bitwise operators?
C has a number of operators like this: +=, |=, &=, -=, /=, *= . They all do the same thing - a combination of a binary operator and an assigment.
a *= b; multiplies a by b and assigns the result to a
a += b; adds a and b and assigns the result to a
a |= b; does a bitwise or of a and b and assigns the result to a
so
is the same as
 DIDR0  = DIDR0 | (1<<ADC5D);
Historically, C has close ties to assembler-language programming. On many machines, |= becomes a single machine-language instruction. These days, compilers are smart enough to figure that out even if you don’t use the combined operator, but it’s part of the C language and is an instantly-recognisable idiom for C programmers. This line of code sets the ADC5D bit in DIDR0.
And, if what you are modifying is a complicated expression it can prevent errors.
Why type *(a->b.c[I*j+k - *g]) twice?
