I ripped apart a scanner I had laying around and came up with some useful stuff, but I cannot find any part numbers or other indication of what the heck this thing is called. I know what it does, I just cannot come up with a name to google the datasheet.
It's an opto-interrupter. Just Google it ![]()
Opto-Interrupter! That makes sense... I tried optical limit switch, and variations of that, but that makes perfect sense ![]()
Thanks!
Okay, now... how would I use it...
I have it wired up and from the signal wire (well, what I am assuming is the signal wire) I receive 3.6v when it is 'open' and zero when it is 'closed', but when I wire it up to turn on/off a led, it barely lights at all...
I checked the current draw through the signal line and I'm reading a 'massive' 5.0uA... Can that be right?
I traced the circuit on the board I took it from, and the signal line is wired directly to the uC (AVISION 162-54-00003 for those curious), now granted, they're not using it to control an led, and for all intents and purposes I would hook it up to a uC anyway, but that seems like an awfully small current to do anything with...
Or am I just confused? ![]()
Gotcha... I knew what it did and how it did it, I was just a little confused with a schematic I found online, I took another look at it and I must have read it wrong the first time... Makes perfect sense now..
Thanks Richard!
Think limit switch as in end of travel, or traffic counter as in light beam entry detector.
