What is VDD_ENV?
I'm studying arduino nano 33 ble rev sense 2. But I don't know where VDD_ENV from. It is just connacted bmi270, bmm150, and BLE 49 pin. Please explain about VDD_ENV.
Where do you see VDD_ENV?
It is from GPIO49.
They used GPIO49 as a power source for most of the onboard sensors.
Not good engineering.
Wow, that's ... interesting.
I am working on a project using Arduino NANO 33 BLE sense rev2. I made a PCB substrate and separated BMI270, NINA B306, MICROPHONE, LED from Arduino and attached it to my PCB substrate. Also, I connected Arduino and PCB substrate to upload and run the code, but BMI270 and Microphone did not work. If possible, could you please look at the scheme of the PCB I made and advise me?
I have attached the schematic pdf file.
schemetic.pdf (55.9 KB)
Can you put the schematic on a single page. It will be easier to read.
How about now?
And this is official Arduino nano 33 ble sense rev2 schemetic. Please compare and tell me what's wrong in my schemetic.
If you look at the bottom of the schematic you will see the phrase:
"Reference Designs ARE PROVIDED "AS IS" AND "WITH ALL FAULTS."
There is no guarantee that the Arduino schematic is correct and there is no point in comparing a schematic that may have errors to your schematic that may also have errors.
In any case your schematic is a little blurry and I don't see any connections for VDD or VBUS
