//this constant won't change
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
// variables will change::
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialise the button pin as a input:
pinMode(buttonPin, INPUT);
// initialise the LED as an output:
pinMode(LED_BUILTIN, OUTPUT);
// initiailise serial communication
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
//if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
it says expected '}' at the end of input
If you format your code and post it properly in tags (or just format it befor coming here) the problem has been clearly identified by the compiler,
Common compiler errors caused by mismatched brackets:
"does not name a type" or
"expected declaration before" or
"expected unqualified-id before"
Usually means you forgot a '{' or put in an extra '}' in the previous function. Since all of the open brackets have been closed, the compiler is looking for further global declarations (variables or functions). If it finds something that looks like executable code instead of a global declaration it emits an error. Make sure that the brackets in the preceding function are in matching pairs '{' followed by '}'.
"a function-definition is not allowed here before '{' token"
(can cause: "'functionName' was not declared in this scope")
Usually means you forgot a '}' or put in an extra '{' in the previous function. Since a set of brackets has not been closed yet the compiler is looking for more code to put in the function. You can't declare a function inside a function so if the compiler finds a function declaration it emits an error. Make sure that the brackets in the preceding function are in matching pairs '{' followed by '}'.
"expected '}' at end of input"
Usually means you forgot a '}' or put in an extra '{' in the last function in the sketch. Since a set of brackets has not been closed yet, the compiler is looking for more code to put in the function. When it hits the end of the file instead it emits an error. Make sure that the brackets in the last function are in matching pairs '{' followed by '}'.
"expected primary-expression before '}' token"
Usually means you have an incomplete statement before a '}'. The block statement (between '{' and matching '}') can only contain complete statements.
