#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#include "Platform.h"
#include "SoftwareSerial.h"
#ifndef CDC_ENABLED
// Shield Jumper on SW
SoftwareSerial port(12,13);
#else
// Shield Jumper on HW (for Leonardo)
#define port Serial1
#endif
#else // Arduino 0022 - use modified NewSoftSerial
#include "WProgram.h"
#include "NewSoftSerial.h"
NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
int LED = 8 ;
//Groups and Commands
enum
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_DEVICE = 0,
enum Group1
G1_LED_ON = 0,
G1_LED_OFF = 1,
EasyVRBridge bridge;
int8_t group, idx;
#ifndef CDC_ENABLED
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
Serial.println("Bridge not started!");
#else
// bridge mode?
if (bridge.check())
port.begin(9600);
bridge.loop(port);
Serial.println("Bridge connection aborted!");
#endif
port.begin(9600);
while (!easyvr.detect())
Serial.println("EasyVR not detected!");
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
easyvr.setLanguage(0);
group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
do
// can do some processing while waiting for a spoken command
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
// built-in trigger (ROBOT)
// group = GROUP_X; <-- jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: ");
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(" = ");
Serial.println(name);
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println("Timed out, try again...");
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
void action()
switch (group)
case GROUP_0:
switch (idx)
case GO_DEVICE:0
group = GROUP_1 ;
// write your action code here
// group = GROUP_X; <-- or jump to another group X for composite commands
case GROUP_1:
switch (idx)
case G1_LED_ON:
digital.Write(8,HIGH)
case G1_LED_OFF:
digital.Write(8,LOW)
group = GROUP_0;
delay(5);
This is a code to turn one LED on and off using an EasyVR Shield 2.0 + Arduino UNO R3
The error I am getting says 'G0_DEVICE' was not declared in this scope. ???What does this mean and how can I fix it?
The yellow highlighted line above is what is highlighted in the Arduino program when I try to verify the code and get the error.
Any help is really appreciated. Been troubleshooting for days and still can't voice command one LED...
