What is wrong with this code?
I just started using Arduino, and was wondering what is wrong with this code. I am sure it has to do something with the boolean and const byte buttons line, but I can't figure it out. BTW I am a total newb at this so dont make fun of me XD
#include <Esplora.h>
boolean buttonStates[1];
const byte buttons[] = {
SWITCH_DOWN,
int fahrenheit = Esplora.readTemperature(DEGREES_F);
if (SWITCH_DOWN == PRESSED) {
Serial.print("It is ");
Serial.print(fahrenheit);
Serial.println(" degrees.");
What benefit is there to a one element array? How is that more useful than a scalar variable?
  SWITCH_DOWN,
What is this supposed to be doing? The name of the variable does NOT suggest what it is supposed to contain.
It is VERY unlikely that these two constants have the same value. Reading a pin somewhere is generally a good idea.
So how do I fix it then? What can I do instead of the array? Also, how do I fix the if command? Thanks!
Why do you need anything? You never refer to the array in the code.
That all depends on what you think you are doing? What have you done about assigning buttons a meaningful name?
Try this:
boolean buttonState;
const byte button = 2;
  pinMode(button, INPUT);
  buttonState =  digitalRead(button);
  if (buttonState == PRESSED) {
