What is wrong with this?
I am pretty much new to Arduino, and I have a little problem over here.
So, I have a code to put voltage on pin 10 for a short amount of time.
I am using the following:
int ledPin = 10;                 // LED connected to digital pin 10
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  digitalWrite(ledPin, HIGH);   // sets the LED on
  delay(1000);                  // waits for a second
  digitalWrite(ledPin, LOW);    // sets the LED off
It does not work. I plugged a cable in the place where it says: DIGITAL PWM 10
I also connected a cable from the breadboard back to ground again.
What is wrong with my setup/code?
The code looks good,
  1. you could change the number from 10 -> 13 and then the on board LED should blink.
  2. How did you connect the LED to pin 10? can you post your schema
I already fixed it.
What I basically tried was this:
I had a $1 step counter, which added 1 step by every time it gets a certain amount of voltage.
So I wanted the arduino to make it a timer instead of a step counter, so I wanted to add 1 number every second.
I tried to clear the eeprom, and then re-uploaded it, and now it seems to work.
