What is wrong with this?
#include “Keyboard.h”
void typeKey(int key)
Keyboard.press(key);
delay(50);
Keyboard.release(key);
/* Init function */
// Begining the Keyboard stream
Keyboard.begin();
// Wait 500ms
Keyboard.press(KEY_LEFT_ALT);
Keyboard.press(KEY_F4);
Keyboard.releaseAll();
// Ending stream
Keyboard.end();
/* Unused endless loop */
void loop() {}
i keep getting this error message;
exit status 1
‘Keyboard’ not found. Does your sketch include the line ‘#include <Keyboard.h>’?
and i if i put that i get the same error message
may be that you are not using code tags? :grin: (or the wrong arduino which does not support the keyboard library - and also that you typeKey() function releases the key so you can’t combine ALT-F4 for example)
Please correct your post above and add code tags around your code:
[code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
Which board are you trying to compile for?
I get the same error if I try to compile the sketch for an Arduino UNO.
When I switch to an Arduino Leonardo, which has support for the Keyboard library, I get no error.
