What is xxx = !xxx Mean ?
I start doing the projects int the Arduino project bookthat come with Arduino Starter kit
in the project 10 called zoetrope that you make a motor with a switch can on the program and another on to change the direction of spining and a poteinometer to control the power I have understand every thing but there are a peice of code that I can not understand
here is the full code :
  Arduino Starter Kit example
 Project 10  - Zoetrope
 This sketch is written to accompany Project 10 in the
 Arduino Starter Kit
 Parts required:
 two 10 kilohm resistors
 2 momentary pushbuttons
 one 10 kilohm potentiometer
 motor
 9V battery
 H-Bridge
 Created 13 September 2012
 by Scott Fitzgerald
 Thanks to Federico Vanzati for improvements
 http://arduino.cc/starterKit
 This example code is part of the public domain
const int controlPin1 = 2; // connected to pin 7 on the H-bridge
const int controlPin2 = 3; // connected to pin 2 on the H-bridge
const int enablePin = 9;   // connected to pin 1 on the H-bridge
const int directionSwitchPin = 4;  // connected to the switch for direction
const int onOffSwitchStateSwitchPin = 5; // connected to the switch for turning the motor on and off
const int potPin = A0;  // connected to the potentiometer's output
// create some variables to hold values from your inputs
int onOffSwitchState = 0;  // current state of the On/Off switch
int previousOnOffSwitchState = 0; // previous position of the on/off switch
int directionSwitchState = 0;  // current state of the direction switch
int previousDirectionSwitchState = 0;  // previous state of the direction switch
int motorEnabled = 0; // Turns the motor on/off
int motorSpeed = 0; // speed of the motor
int motorDirection = 1; // current direction of the motor
void setup(){
  // intialize the inputs and outputs
  pinMode(directionSwitchPin, INPUT);
  pinMode(onOffSwitchStateSwitchPin, INPUT);
  pinMode(controlPin1, OUTPUT);
  pinMode(controlPin2, OUTPUT);
  pinMode(enablePin, OUTPUT);
  // pull the enable pin LOW to start
  digitalWrite(enablePin, LOW);
void loop(){
  // read the value of the on/off switch
  onOffSwitchState = digitalRead(onOffSwitchStateSwitchPin);
  delay(1);
  // read the value of the direction switch
  directionSwitchState = digitalRead(directionSwitchPin);
  // read the value of the pot and divide by 4 to get
  // a value that can be used for PWM
  motorSpeed = analogRead(potPin)/4;
  // if the on/off button changed state since the last loop()
  if(onOffSwitchState != previousOnOffSwitchState){
    // change the value of motorEnabled if pressed
    if(onOffSwitchState == HIGH){
      motorEnabled = !motorEnabled;
  // if the direction button changed state since the last loop()
  if (directionSwitchState != previousDirectionSwitchState) {
    // change the value of motorDirection if pressed
    if (directionSwitchState == HIGH) {
      motorDirection = !motorDirection;
  // change the direction the motor spins by talking
  // to the control pins on the H-Bridge
  if (motorDirection == 1) {
    digitalWrite(controlPin1, HIGH);
    digitalWrite(controlPin2, LOW);
  else {
    digitalWrite(controlPin1, LOW);
    digitalWrite(controlPin2, HIGH);
  // if the motor is supposed to be on
  if (motorEnabled == 1) {
    // PWM the enable pin to vary the speed
    analogWrite(enablePin, motorSpeed);
  else { // if the motor is not supposed to be on
    //turn the motor off
    analogWrite(enablePin, 0);
  // save the current On/Offswitch state as the previous
  previousDirectionSwitchState = directionSwitchState;
  // save the current switch state as the previous
  previousOnOffSwitchState = onOffSwitchState;
and that is the part that I do not understand
  else {
espicially this statement :
See Boolean operators
If xxx was zero (or low), now it is one (or high). If xxx was one, now it is zero.
It is making the direction of the motor zero or one, depending on its previous state. Eg, switching rotation.
I have NOT, a clue what it means :smiling_imp:
Riva:
You might even say
motorDirection =  not motorDirection;
:smiling_imp:
First, you initialize motorDirection to 1. Let's assume a 1 means clockwise (CW) rotation and 0 means counter-clockwise (CCW) direction. Then, in your code you have:
  if (directionSwitchState != previousDirectionSwitchState) {   // This says if current direction is not
        // the same as the new direction we want...
    if (directionSwitchState == HIGH) {                    // If switch for a motor direction change is active...
      motorDirection = !motorDirection;                    // change directions.
In the code block above, if motorDirection was 1 it was rotating CW. The NOT operator (!) says whatever the value of motorDirection is, "flip its value". Since it is currently 1, NOT 1 is 0, so the motor would reverse its direction to CCW. If, instead, motorDirection was 0 and was moving CCW, the NOT operator would change its value to 1 and it would reverse direction to CW.
