This is the SSD1306Ascii_Button_Navigation
from ArduinoMenu-master
that mentioned joystick
, but the config.h
just defined 4 BTNs, that I can't figure out what Joystick used and how to wiring?
Thanks for help please.
Adam
Button_Navigation:
Sketch: MENU NAVIGATION WITH JUST 4 BUTTONS
This Sketch displays Menu without any Serial Communication and the
navigation is performed by 4 buttons attached to D3, D8, D4 and D1.
Also, attach led on D11 to control brightness from menu.
Default brightness is 15% (check line 78)
NOTE: By default, navigation buttons use INTERNAL_PULLUP feature.
This can be changed by commenting the line 45 in "config.h" file
Uses SSD1306Ascii Library(https://github.com/greiman/SSD1306Ascii)
by Bill Grieman
Created by Tamojit Saha
Github: https://github.com/TamojitSaha
Website: https://www.tamojitsaha.info/
#include <Arduino.h>
// #include <Wire.h>
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
#include <menu.h>
#include <menuIO/SSD1306AsciiOut.h>
#include <menuIO/keyIn.h>
//#include <menuIO/chainStream.h>
using namespace Menu;
SSD1306AsciiWire oled;
#include "config.h"
int ledCtrl = HIGH; //Default LED State of LED at D11 is LOW
result doAlert(eventMask e, prompt &item);
result showEvent(eventMask e, navNode& nav, prompt& item) {
return proceed;
result action1(eventMask e) {
return proceed;
result action2(eventMask e, navNode& nav, prompt &item) {
//Serial.print(e);
//Serial.println(" action2 executed, quiting menu");
return quit;
result ledOn() {
ledCtrl = HIGH;
analogWrite(LED_PIN, 255);
return proceed;
result ledOff() {
ledCtrl = LOW;
analogWrite(LED_PIN, 0);
return proceed;
result internalLedOn() {
digitalWrite(LED_BUILTIN, HIGH);
return proceed;
result internalLedOff() {
analogWrite(LED_BUILTIN, LOW);
return proceed;
int brightnessValue = 15; //Default LED brightness value
result adjustBrightness() {
if (ledCtrl == HIGH) {
int pwm = int(2.55 * float(brightnessValue));
analogWrite(LED_PIN, pwm);
return proceed;
TOGGLE(ledCtrl, setLed, "Led: ", doNothing, noEvent, noStyle //,doExit,enterEvent,noStyle
, VALUE("On", HIGH, ledOn, enterEvent)//ledOn function is called
, VALUE("Off", LOW, ledOff, enterEvent)//ledOff function is called
int selTest = 0;
SELECT(selTest, selMenu, "Select", doNothing, noEvent, noStyle
, VALUE("Zero", 0, doNothing, noEvent)
, VALUE("One", 1, doNothing, noEvent)
, VALUE("Two", 2, doNothing, noEvent)
int chooseTest = -1;
CHOOSE(chooseTest, chooseMenu, "Choose", doNothing, noEvent, noStyle
, VALUE("First", 1, doNothing, noEvent)
, VALUE("Second", 2, doNothing, noEvent)
, VALUE("Third", 3, doNothing, noEvent)
, VALUE("Last", -1, doNothing, noEvent)
//customizing a prompt look!
//by extending the prompt class
class altPrompt: public prompt {
public:
altPrompt(constMEM promptShadow& p): prompt(p) {}
Used printTo(navRoot &root, bool sel, menuOut& out, idx_t idx, idx_t len, idx_t) override {
return out.printRaw(F("special prompt!"), len);
MENU(subMenu, "Sub-Menu", showEvent, anyEvent, noStyle
, OP("Sub1", showEvent, anyEvent)
, OP("Sub2", showEvent, anyEvent)
, OP("Sub3", showEvent, anyEvent)
, altOP(altPrompt, "", showEvent, anyEvent)
, EXIT("<Back")
MENU(mainMenu, "Main menu", doNothing, noEvent, wrapStyle
, OP("Op1", action1, anyEvent)
, OP("Op2", action2, enterEvent)
/* FIELD Parameters :
Action Name(function name), Action Heading, Action Heading Unit,
range_lowest, range_highest, range_increment_step,
range_decrement_step
, FIELD(brightnessValue, "Brightness", "%", 0, 100, 5, 5, adjustBrightness, enterEvent, wrapStyle)
, SUBMENU(subMenu)
, SUBMENU(setLed)
, OP("LED On", internalLedOn, enterEvent) // will turn on built-in LED
, OP("LED Off", internalLedOff, enterEvent)// will turn off built-in LED
, SUBMENU(selMenu)
, SUBMENU(chooseMenu)
, OP("Alert test", doAlert, enterEvent)
, EXIT("<Back")
//describing a menu output device without macros
//define at least one panel for menu output
const panel panels[] MEMMODE = {{0, 0, 128 / fontW, 64 / fontH}};
navNode* nodes[sizeof(panels) / sizeof(panel)]; //navNodes to store navigation status
panelsList pList(panels, nodes, 1); //a list of panels and nodes
idx_t tops[MAX_DEPTH] = {0, 0}; //store cursor positions for each level
#ifdef LARGE_FONT
SSD1306AsciiOut outOLED(&oled, tops, pList, 8, 2); //oled output device menu driver
#else
SSD1306AsciiOut outOLED(&oled, tops, pList, 5, 1); //oled output device menu driver
#endif
menuOut* constMEM outputs[] MEMMODE = {&outOLED}; //list of output devices
outputsList out(outputs, 1); //outputs list
#ifdef NAV_BUTTONS_INPUT_PULLUP
//build a map of keys to menu commands
keyMap joystickBtn_map[] = {
{ -BTN_SEL, defaultNavCodes[enterCmd].ch} ,
{ -BTN_UP, defaultNavCodes[upCmd].ch} ,
{ -BTN_DOWN, defaultNavCodes[downCmd].ch} ,
{ -BTN_ESC, defaultNavCodes[escCmd].ch} ,
keyIn<TOTAL_NAV_BUTTONS> joystickBtns(joystickBtn_map);//the input driver
#else
{ BTN_SEL, defaultNavCodes[enterCmd].ch} ,
{ BTN_UP, defaultNavCodes[upCmd].ch} ,
{ BTN_DOWN, defaultNavCodes[downCmd].ch} ,
{ BTN_ESC, defaultNavCodes[escCmd].ch},
#endif
NAVROOT(nav, mainMenu, MAX_DEPTH, joystickBtns, out);
result alert(menuOut& o, idleEvent e) {
if (e == idling) {
o.setCursor(0, 0);
o.print("alert test");
o.setCursor(0, 1);
o.print("press [select]");
o.setCursor(0, 2);
o.print("to continue...");
return proceed;
result doAlert(eventMask e, prompt &item) {
nav.idleOn(alert);
return proceed;
//when menu is suspended
result idle(menuOut &o, idleEvent e) {
o.clear();
switch (e) {
case idleStart: o.println("suspending menu!"); break;
case idling: o.println("suspended..."); break;
case idleEnd: o.println("resuming menu."); break;
return proceed;
joystickBtns.begin();
pinMode(LED_PIN, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
Wire.begin();
oled.begin(&Adafruit128x64, OLED_I2C_ADDRESS); //check config
oled.setFont(menuFont);
oled.clear();
nav.idleTask = idle; //point a function to be used when menu is suspended
nav.poll();
delay(1);//simulate a delay when other tasks are done
config.h
/*config.h*/
/* List of Supported Fonts
Arial14,
Arial_bold_14,
Callibri11,
Callibri11_bold,
Callibri11_italic,
Callibri15,
Corsiva_12,
fixed_bold10x15,
font5x7, //Do not use in LARGE_FONT, can use as default font
font8x8,
Iain5x7, //Do not use in LARGE_FONT, can use as default font
lcd5x7, //Do not use in LARGE_FONT, can use as default font
Stang5x7, //Do not use in LARGE_FONT, can use as default font
System5x7, //Do not use in LARGE_FONT, can use as default font
TimesNewRoman16,
TimesNewRoman16_bold,
TimesNewRoman16_italic,
utf8font10x16,
Verdana12,
Verdana12_bold,
Verdana12_italic,
X11fixed7x14,
X11fixed7x14B,
ZevvPeep8x16
#define OLED_I2C_ADDRESS 0x3C //Defined OLED I2C Address
* Define your font from the list.
* Default font: lcd5x7
* Comment out the following for using the default font.
#define LARGE_FONT Verdana12
//Navigate buttons
#define BTN_SEL 3 // Select button
#define BTN_UP 8 // Up Button
#define BTN_DOWN 4 // Down Button
#define BTN_ESC 1 // Exit Button
// Comment the following to disable internal pullup for Navigate buttons
#define NAV_BUTTONS_INPUT_PULLUP
#define TOTAL_NAV_BUTTONS 4 // Total Navigation Button used
/*Demonstrate PWM with LED on D11*/
#define LED_PIN 11 //Defined LED Pin to D11
#define MAX_DEPTH 2
#ifdef LOC
// #define LARGE_FONT
#define INV
#endif
/*Do not change the values(recomended)*/
#ifdef LARGE_FONT
#define menuFont LARGE_FONT
#define fontW 8
#define fontH 16
#else
// #define menuFont System5x7
#define menuFont lcd5x7
#define fontW 5
#define fontH 8
#endif
what I have is this, can it be used here?
