I come from Belgium so, please excuse my poor level in English. I'm a new bachelor in electromecanical engineering and a beginner in electronic. Actually, i learn C by myself.
I've a project that would required a arduino but i don't know which.
So, I have:
-> A Hall sensor (for exemple) to know the speed of a wheel (40/60 rotation per second max).
-> The arduino should switch a relay when the speed of the wheel exceeds a maximum value to a minimum value.
-> I must change the minimum and maximum value (by a variable resistor for exemple) and perhaps display it.
-> He must incorporate improvements (tilt sensor,...)
=> Could you help me to choose what kind of arduino i must buy? The arduino is powerful enough to handle it?
Your probably better off just getting the newest 'standard' arduino board, the Uno model. It would handle all the things you listed. Other board models just offer more I/O pins and memory for larger applications, or some are smaller for direct mounting onto breadboards or direct integration on to another custom PCB.
