what kind of language is it, it does not look like the regular C
PaulS:
That code already puts the data in an array. If you don't want to send it to the serial port, don't.
I know that the data collected from A0 pin goes into memory, I just cannot figure out the coding.
Can I transfer the data later for example into array, making sure it does not slow the sampling rate.
if I declare array like this.
int myArray[2000];
how do I put the data into myArray[1], myArray[2], ....., myArray[2000]
thanks
