What kind of light dimmer is this?
Hello!
In my bedroom, I have a light dimmer / switch (100_0016.JPG). What kind of dimmer is it? Is it a...
a) Capacitive Sensor
b) Pressure Sensor
c) Something else (specify)
How do capacitive sensors work?
Thanks!
No idea from that blurry photo.
b) Pressure Sensor
How do you interact with it.
If you can control it with out actually touching it then it is capacitive. If you see some deformation before it changes then it is pressure.
By sensing capacitance between the plate and ground as your body affects it.
Grumpy_Mike:
How much more detail is there to see? If you don't maximize the photo, it will be easier to see (my camera takes 5.0 Mega pixels).
Grumpy_Mike:
You touch it with your finger. The pad seems to be made of metal, but I have a similar dimmer with a plastic coating.
Grumpy_Mike:
Would the "ground" be "the Earth" in this case?
In Arduino, capacitive sensing only works when you connect it to the Earth somehow (e.g. desktop, USB adapter). Why can't Arduino use the battery's negative terminal as a ground?
There is no choice with this forum.
Yes
No you can get capacitance between any two connections.
The arduino capacitance sensor method is not very good, it is only a sort of demo.
To do it properly you need a controlled layout and an oscillator that changes with capacitance then you measure the frequency.
So that could be an inductive injection. Or it could be capacitive.
So that would be capacitive.
It is extremely hard, if not impossible, to tell what a circuit is doing by just looking at the outside case.
