My driveway gate opener is a commercial mechanism. All the control options mentioned are available to control the gate operation. After considering all those options, I chose to use simple push-button switches on each side of the gate. They are mounted on posts so the driver can press the button.
The control has a minimum of two minutes between gate open an gate close. The system has operated flawlessly for nearly 10 years.
When I searched I look for one specifically for Arduino and I couldn't seem to find anyting that would work exactly the way I want. Mainly being outdoors and not able to be affixed perfectly in line without possibility of small movements. I did find a photoelectric sensor that uses a reflector, it connects a relay so it should work with Arduino
There are other manufacturers. All sorts of outputs are available with DC outputs quite common (24V/36V). They're spendy compared to hobby/DIY stuff but generally you mount them, wire'em up, align them and they just work.
The bitterness of poor quality remains long after the sweetness of low price is forgotten. - Ben Franklin.
