What kind of sensors are?
What kind of sensors are? puts on the features which are 2pcs buzzer but not equal, one is more big than other..
Insufficient data.
You need to take a closer photo and post any labeling on the sensors.
They look like piezo buzzers from what you show in the images. They are obviously different makes/designs as one has the back enclosed with resin and the other is open.
They do look similar, but a piezo is not usually referred to as a sensor , though it could be used as microphone. If the OP thought they were microphones wouldn't he call them that ? (granted where a Newbie is concerned, anything is possible).
raschemmel:
ooo i think a battery ~3000mah an d25c will be fine for 10 min flight? Am i wrong? is there is something else that I should concider ?
Hi raschemmel,
Not sure where your random quote above came from but I suspect your crossing your replies. :~
The OP quotes...
so I figured if they look like piezo (that can be used for knock sensors) and the OP refers to buzzers, they probably are buzzers.
They look like potted plants. African Violets perhaps?
Correct. It was either that or I forgot to click "copy" and wound up pasting whatever was on the clipboard.
Thankkks!
Then, can be used as subwoofers or microphone?
Very poor images and I hate things like image shack and that sort of rubbish!! Why can't people just post their piccys? They look like normal mechanical buzzers to me, well one looks identical to one. I have, I use it on my bots and drive it via a 2N7000 FET.
Do they look like these??
Hope it helps, regards.
Mel.
No and yes.
Sorry for the pictures, I don't know how loaded.
Yes your pcs are same.
My pcs not the same, because one pcs have a pin more long than other and have a paste. The other one your pins have the same size and not have a paste.
And my other question, ¿Can be used as subwoofers or microphone? The answer for raschemmel..I don't understand :S
Thankks!
No not really as they are incapable of producing such a sound range, their mechanical buzzers NOT speakers! Sub/Woofers are large by nature to produce such sounds, a tiny tinny speaker gives you a tinny squicky sound... But their alright for my buggy-bot beeps, etc..
A piezo device could make a microphone/sound detector if amplified enough, I think, never tried it!!
Regards
Mel.
OHHHH, I understandd thankkss!
