What language are microcontrollers coded in (rookie question)
To what I have picked up so far microcontrollers are coded in c++ is this the case for every mcu?
Thanks
No. A large number use C, some use a dialect of Basic, and there are other specialty languages. For the most part, the Arduino family gets along pretty well with C/C++.
Sort of. Also, sort of not. The controllers themselves use machine language. The IDE used to program them converts your code into this machine language. This is why I said "sort of" instead of "yes" or "no." You type your code into the IDE using C++. However, some controllers use other languages in their respective IDEs. For example, the BASIC Stamp (Parallax) uses the BASIC language.
PRE-POST EDIT
ninja'd, but posting anyways.
Pcbs are not 'coded' at all. (it was in the old thread title)
http://www.allacronyms.com/PCBS
:slightly_smiling_face:
econjack:
Right ok thanks do both have the same functions?
free-bee:
PRE-POST EDIT
would it be the same using a bootloader?
Thanks
Download the AVR datasheet for detailed information.
The OP asked for the time and we tell him how to build a clock. Since the question was asked on an Arduino Forum, I would assume he was concerned with the language used in this environment. To clarify my answer: For the Arduino family using the Arduino IDE, C and C++ are the most popular languages used here.
