What lines of Code to remove if not using PIR sensor?
I’ve spent hours trying to remove and mirror a different sketch to get this to run without using a PIR sensor. Basically, I’m going to put a switch in the power line to turn this sequence on and off. I’m not going to use an input pin or a PIR sensor and want to know what lines to remove to make this loop over and over without the use of a PIR sensor. I want to be able to turn switch the power on and then have this sequence loop over and over until I turn the power off.
Here’s the sketch I’m working with. I appreciate the help.
 * PIR sensor tester
int ledPin = 13;                // choose the pin for the LED
int inputPin = 2;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
int ledPin1 = 9;
int ledPin2 = 6;
int ledPin3 = 5;
int ledPin4 = 3;
int surroundPin = 11;
int fadespeed = 10;
int timeTravelSpeed = 80;
int timeTravelLength = 25;
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  //Serial.begin(9600);
void loop(){
  val = digitalRead(inputPin);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(ledPin, HIGH);  // turn LED ON
    runlights(); //run the light show!
    if (pirState == LOW) {
      // we have just turned on
      //Serial.println("Motion detected!");
      // We only want to print on the output change, not state
      pirState = HIGH;
    digitalWrite(ledPin, LOW); // turn LED OFF
    if (pirState == HIGH){
      // we have just turned of
      //Serial.println("Motion ended!");
      pirState = LOW;
void runlights(){
  //Speed up loops
  for (int fadeIncrement = 20; fadeIncrement <=100; fadeIncrement +=2){
    for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=fadeIncrement) {
      analogWrite(ledPin1, fadeValue);
      delay(fadespeed);
    for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=fadeIncrement) {
      delay(fadespeed);
    analogWrite(ledPin1, 0);
      analogWrite(ledPin2, fadeValue);
      delay(fadespeed);
      delay(fadespeed);
    analogWrite(ledPin2, 0);
      analogWrite(ledPin3, fadeValue);
      delay(fadespeed);
      delay(fadespeed);
    analogWrite(ledPin3, 0);
      analogWrite(ledPin4, fadeValue);
      delay(fadespeed);
      delay(fadespeed);
    analogWrite(ledPin4, 0);
  //time travel loops
  for (int timetravel = 1; timetravel <=timeTravelLength; timetravel +=1){
    //turn on surround lights
    for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=15) {
      analogWrite(surroundPin, fadeValue);
      delay(fadespeed);
    //Run time travel lights
    for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=timeTravelSpeed) {
      delay(fadespeed);
    for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=timeTravelSpeed) {
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
   //fade out the surround lights
    for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=15) {
      delay(fadespeed);
The code is so terrible and it’s so simple to fix I shouldn’t actually give you the answer but okay…
 * PIR sensor tester
//int ledPin = 13;                // choose the pin for the LED
//int inputPin = 2;               // choose the input pin (for PIR sensor)
//int pirState = LOW;             // we start, assuming no motion detected
//int val = 0;                    // variable for reading the pin status
int ledPin1 = 9;
int ledPin2 = 6;
int ledPin3 = 5;
int ledPin4 = 3;
int fadespeed = 10;
void loop(){
      pirState = HIGH;
      pirState = LOW;
  runlights();
void runlights(){
  //Speed up loops
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
  //time travel loops
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
      delay(fadespeed);
TIP: just learn how to program if you want to do more Arduino projects…
That's tough love right there. I appreciate the help.
