Hi! I’ve been using Arduino for a few years and done some projects with different Arduino and tools, but now i want to make games on a LCD display, so i looked for examples and ideas and i found a game about a runner who jumps and avoids random terrains, however when a look the code i couldn’t understand a lot of sentences that I’ve never seen before. Could you help me what means the marked ones? Thanks!
Here’s the entire code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
static char terrainUpper[TERRAIN_WIDTH + 1];
static char terrainLower[TERRAIN_WIDTH + 1];
static bool buttonPushed = false;
static int melodyPin = 3;
void initializeGraphics() {
static byte graphics = {
// Run position 1
B01100,
B01100,
B00000,
B01110,
B11100,
B01100,
B11010,
B10011,
// Run position 2
B01100,
B01100,
B00000,
B01100,
B01100,
B01100,
B01100,
B01110,
// Jump
B01100,
B01100,
B00000,
B11110,
B01101,
B11111,
B10000,
B00000,
// Jump lower
B11110,
B01101,
B11111,
B10000,
B00000,
B00000,
B00000,
B00000,
// Ground
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
// Ground right
B00011,
B00011,
B00011,
B00011,
B00011,
B00011,
B00011,
B00011,
// Ground left
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
B11000,
int i;
// Skip using character 0, this allows lcd.print() to be used to
// quickly draw multiple characters
for (i = 0; i < 7; ++i) {
lcd.createChar(i + 1, &graphics[i * 8]); // Creates the character
for (i = 0; i < TERRAIN_WIDTH; ++i) {
terrainUpper = SPRITE_TERRAIN_EMPTY; //cleans the entire screen with empty terrains
terrainLower = SPRITE_TERRAIN_EMPTY;
// Slide the terrain to the left in half-character increments
void advanceTerrain(char* terrain, byte newTerrain) {
for (int i = 0; i < TERRAIN_WIDTH; ++i) {
_ char current = terrain*;_
char next = (i == TERRAIN_WIDTH - 1) ? newTerrain : terrain[i + 1];
_ switch (current) {_
case SPRITE_TERRAIN_EMPTY:
terrain = (next == SPRITE_TERRAIN_SOLID) ? SPRITE_TERRAIN_SOLID_RIGHT : [/color]SPRITE_TERRAIN_EMPTY;
_ break;_
case SPRITE_TERRAIN_SOLID:
terrain = (next == SPRITE_TERRAIN_EMPTY) ? SPRITE_TERRAIN_SOLID_LEFT : SPRITE_TERRAIN_SOLID;[/color]
_ break;_
case SPRITE_TERRAIN_SOLID_RIGHT:
terrain = SPRITE_TERRAIN_SOLID;
_ break;_
case SPRITE_TERRAIN_SOLID_LEFT:
terrain = SPRITE_TERRAIN_EMPTY;
_ break;
}_
_bool drawHero(byte position, char terrainUpper, char* terrainLower, unsigned int score) {
bool collide = false;
char upperSave = terrainUpper[HERO_HORIZONTAL_POSITION];
char lowerSave = terrainLower[HERO_HORIZONTAL_POSITION];
byte upper, lower;
switch (position) {
* case HERO_POSITION_OFF:
upper = lower = SPRITE_TERRAIN_EMPTY;*
* break;_
case HERO_POSITION_RUN_LOWER_1:
upper = SPRITE_TERRAIN_EMPTY;
lower = SPRITE_RUN1;
_ break;_
case HERO_POSITION_RUN_LOWER_2:
lower = SPRITE_RUN2;
_ break;_
case HERO_POSITION_JUMP_1:
case HERO_POSITION_JUMP_8:
lower = SPRITE_JUMP;
_ break;_
case HERO_POSITION_JUMP_2:
case HERO_POSITION_JUMP_7:
upper = SPRITE_JUMP_UPPER;
lower = SPRITE_JUMP_LOWER;
_ break;_
case HERO_POSITION_JUMP_3:
case HERO_POSITION_JUMP_4:
case HERO_POSITION_JUMP_5:
case HERO_POSITION_JUMP_6:
upper = SPRITE_JUMP;
_ break;_
case HERO_POSITION_RUN_UPPER_1:
upper = SPRITE_RUN1;
_ break;_
case HERO_POSITION_RUN_UPPER_2:
upper = SPRITE_RUN2;
_ break;
if (upper != ’ ') {_
terrainUpper[HERO_HORIZONTAL_POSITION] = upper;
collide = (upperSave == SPRITE_TERRAIN_EMPTY) ? false : true;
_}
if (lower != ’ ') {_
terrainLower[HERO_HORIZONTAL_POSITION] = lower;
collide |= (lowerSave == SPRITE_TERRAIN_EMPTY) ? false : true;
_}
byte digits = (score > 9999) ? 5 : (score > 999) ? 4 : (score > 99) ? 3 : (score > 9) ? 2 : 1;
// Draw the scene*
terrainUpper[TERRAIN_WIDTH] = ’ ';
terrainLower[TERRAIN_WIDTH] = ’ ';
char temp = terrainUpper[16 - digits];
terrainUpper[16 - digits] = ’ ';
lcd.setCursor(0, 0);
lcd.print(terrainUpper);
terrainUpper[16 - digits] = temp;
lcd.setCursor(0, 1);
lcd.print(terrainLower);
lcd.setCursor(16 - digits, 0);
lcd.print(score);
terrainUpper[HERO_HORIZONTAL_POSITION] = upperSave;
terrainLower[HERO_HORIZONTAL_POSITION] = lowerSave;
return collide;
// Handle the button push as an interrupt
void buttonPush() {
buttonPushed = true;
initializeGraphics();
* lcd.init();
lcd.init();
lcd.backlight();
buttonCheck();
static byte heroPos = HERO_POSITION_RUN_LOWER_1;
static byte newTerrainType = TERRAIN_EMPTY;
static byte newTerrainDuration = 1;
static bool playing = false;
static bool blink = false;
static unsigned int distance = 0;
if (!playing) {_
drawHero((blink) ? HERO_POSITION_OFF : heroPos, terrainUpper, terrainLower, distance >> 3);
_ if (blink) {
lcd.print(“Press Start”);
delay(250);
blink = !blink;
if (buttonPushed) {
initializeGraphics();_
_ playing = true;
distance = 0;
return;
// Shift the terrain to the left*
advanceTerrain(terrainLower, newTerrainType == TERRAIN_LOWER_BLOCK ? SPRITE_TERRAIN_SOLID : SPRITE_TERRAIN_EMPTY);
advanceTerrain(terrainUpper, newTerrainType == TERRAIN_UPPER_BLOCK ? SPRITE_TERRAIN_SOLID : SPRITE_TERRAIN_EMPTY);
// Make new terrain to enter on the right
if (–newTerrainDuration == 0) {
* if (newTerrainType == TERRAIN_EMPTY) {
newTerrainType = (random(3) == 0) ? TERRAIN_UPPER_BLOCK : TERRAIN_LOWER_BLOCK;*
* newTerrainDuration = 2 + random(10);
} else {_
_ newTerrainDuration = 10 + random(10);
if (buttonPushed) {_
if (heroPos <= HERO_POSITION_RUN_LOWER_2) heroPos = HERO_POSITION_JUMP_1;
_ buttonPushed = false;
if (drawHero(heroPos, terrainUpper, terrainLower, distance >> 3)) {
playing = false; // The hero collided with something. Too bad.
} else {_
if (heroPos == HERO_POSITION_RUN_LOWER_2 || heroPos == HERO_POSITION_JUMP_8) {
} else if ((heroPos >= HERO_POSITION_JUMP_3 && heroPos <= HERO_POSITION_JUMP_5) && terrainLower[HERO_HORIZONTAL_POSITION] != SPRITE_TERRAIN_EMPTY) {
heroPos = HERO_POSITION_RUN_UPPER_1;
} else if (heroPos >= HERO_POSITION_RUN_UPPER_1 && terrainLower[HERO_HORIZONTAL_POSITION] == SPRITE_TERRAIN_EMPTY) {
heroPos = HERO_POSITION_JUMP_5;
} else if (heroPos == HERO_POSITION_RUN_UPPER_2) {
_ } else {
++heroPos;
++distance;
delay(100);
void buttonCheck() {
int b = analogRead(A0); // I’m using a Joystick in A0, so that’s why i don’t use a digital pin for a button
if (b > 850) {
}*_
