What pin number of Tx and Rx for gps and gsm for this code need to connect?
I dont know how to connect the pin of tx and rx for gps and gsm. Need to define it or not?
#include <AltSoftSerial.h>
#include <TinyGPS++.h>
#include <GSM.h>
static const uint32_t GPSBaud = 9600; //Baud rate for communication with the GPS, Adafruit GPS = 9600, your GPS may well be 4800, check the spec
TinyGPSPlus gps; // The TinyGPS++ object for interfacing with the GPS
AltSoftSerial ss; // The serial connection object to the GPS device
String yourPassword = "Location"; // Put the password here between the ""
String password; // Temporary variable used for comparison of passwords
GSM gsmAccess; // Initialise the library instances
GSM_SMS sms;
char senderNumber[20]; // Array to hold the number a SMS is retreived from
  ss.begin(GPSBaud); // begin the GPS serial connection
  Serial.begin(9600); // begin Serial communication with the computer at 9600 baud rate
  Serial.println("Where's my wheels?"); // Print to the computer
  Serial.println("Initialising...");
  Serial.println("GSM initialized");      // print to the computer
  Serial.println("Waiting for messages");
  while (ss.available() > 0) //while there is stuff in the buffer
    if (gps.encode(ss.read())) //if it can successfully decode it, do it. Else try again when more charachters are in the buffer
  if (sms.available()) // if a text has been recieved
    Serial.println("Message received from:"); // print to the computer
    sms.remoteNumber(senderNumber, 20); // assign the sender number to the "senderNumber" variable
    Serial.println(senderNumber); // print the sender number to the computer
    password = ""; // flush the temporary variable
    char c;
    while(c=sms.read())
      password += c; // append the sms to the "password" variable
    Serial.println(password); // print the contents of the sms
    Serial.println("\nEND OF MESSAGE"); // print to the computer
    sms.flush(); // delete message from modem buffer
    Serial.println("MESSAGE DELETED"); // print to the computer
    if (password == yourPassword) // if the sms contains the correct password
      Serial.println("\nPASSWORD VALID"); // print to the computer
      sms.beginSMS(senderNumber); // begin an sms to the sender number
      sms.print(gps.location.lat(), 6); // append the lat to the sms
      sms.print(","); // append a comma
      sms.print(gps.location.lng(), 6); // append the lon to the sms
      sms.endSMS(); //send the sms
    else Serial.println("\nPASSWORD NOT VALID"); // print to the computer
  delay(1000); // delay
No. AltSoftSerial is tied to pins 8 and 9.
tinygps++ pins is ?
Need4Helps:
tinygps++ pins is ?
There are no specific pins for TinyGPS++. You are just feeding it the stream from AltSoftSerial in this line:
Need4Helps:
