what pins correspond to what inputs/outputs on potentiometer?
on the blue 10k potentiometers, which pins correspond to what inputs and outputs? there are two on the left and one on the right. thanks
There are a lot of potentiometers of various colors, and the blue ones I've seen just have the three pins in a line (A, W, B).
But on a pot if you see 2 pins in one group, and one in the other, the two pins are the ends of the pot (A and B in common notation) and the lone pin is the wiper.
Get your multimeter out and measure :wink:
This is in the wrong forum; it has nothing to do with Arduino, the software.
A simple ohmmeter would answer this question. And by “simple” I mean a free-to-$5-Harbor Freight Special will do the job. You don’t need a $500 Fluke.
Consider the three pins on a pot. The outermost pins usually represent the endpoints of the travel, and the center one is the wiper.
thus, a pot with the arrangement
|    o  1           3   o  |
|          2  o            |
corresponds to the schematic symbol
1
> <-----2
3
In the simplest universe of Arduino circuitry you would connect pin 1 to +Vcc (5V or 3.3, depending on your board).
Pin 2 connects to an ADC pin, such as A0, A1. A2…etc.
Pin 3 connects to ground.
Note that for Cortek M-series boards, the voltage on pin 2 must not exceed 1.0V. Read the specs for analog inputs for your chip.
@kwollner, do not cross-post. Threads merged.
flounder:
That's not so. As a specific example the input voltage on the STM32F103 can be anywhere between GND and Vref+. Vref+ can be up anything up the the supply voltage.
