what power bank specification should i use to powering arduino and raspberry pi
i have a power bank for powering arduino and rpi,
the power bank is made from HK , i have it because my brother give it.
for the power bank i cant find the ampere
this is the screenshot
the problem is when i am powering rpi which connected to arduino with powerbank for the first time it works well and it always powered off suddenly
i have tried to powering rpi with powerbank without arduino and it works well and also
i have tried to powering arduino with powerbank without rpi and it works well and
but for both it always turned off suddenly, so i am guessing the problem is on power source
so may i know the recommended power bank specification for powering arduino and rpi together?
The Pi needs about 1A: Raspberry Pi Documentation
What do you connect to the Arduino? LEDs? Motors? What?
I think you need at least a 1.5A power supply.
fungus:
The Pi needs about 1A: http://www.raspberrypi.org/help/faqs/#powerReqs
i connect arduino with GPS ls20031
and for rpi
smartfren modem Connex Evdo USB modem
how can i calculate the voltage / ampere ? is there any formula for it?
shiningstone:
There is formula for small things like resistors but not for things with hundreds of components together.
The only way is to measure each component with a multimeter then add it up.
You either look it up in the data sheet or measure it yourself.
Grumpy_Mike:
no datasheet provided, for this USB modem.
https://www.google.co.id/search?q=smartfren+connvex+evdo+ac682+datasheet&oq=smartfren+connvex+evdo+ac682+datasheet&aqs=chrome..69i57.5162j0j7&sourceid=chrome&es_sm=88&ie=UTF-8
Then you have to measure it.
