what resistor should I be using for these 12v 50mA momentary buttons for my Ar3
This is an example Arduino code to use the read the button and execute the servo motor when button is pressed.
const int IButton = 10; //Idle speed button
pinMode(IButton, INPUT);
IBState = digitalRead(IButton); // read the state of the Idle pushbutton value
if (IBState == HIGH) { // run the Idle speed function
delay(250); // to debounce button
Idle(); // go to Idle function
My guess is I can use 10K ohm resistor as well as the Arduino R3 internal pull-up resistor too.
