What resistor?
I've got some lovely LEDs, they're 2.5-3.5V with a forward current of 25mA. I've bought them because they're bright.
An LED resistor calculator advised I need a 1/8W 82 ohm resistor.
These are a bit tricky to find locally.
Q. Would a 1/4W 100 ohm resistor cut the mustard instead? i.e. It doesn't matter that it's rated for a 1/4W instead of a 1/8W? This won't make any difference, right?
as I would need to buy this resistor,
Q. I have these resistors: 560 Ohm, 2.2k Ohm, 10k Ohm.
If I use the 560 ohm resistor, the LED won't be nearly as bright as when the new resistors arrive, right?
Dane: I've got some lovely LEDs, they're 2.5-3.5V with a forward current of 25mA. I've bought them because they're bright.
Not much, I would suspect you would hardly be able to tell a brightness difference between 20ma Vs 25ma. Wattage difference is not a factor other then taking up a little more space.
Correct, it would light up, but at very reduced brightness. Lefty
OK - the resistor is in the circuit to limit current. A larger value will allow a lower current to flow. As long as it isn't too big the LED will light. With a larger value resistor the LED won't be as bright, because less current is flowing. the 1/8W, 1/4W is how much heat the resistor can get rid of. A larger value there won't hurt you in any way. A smaller value than recommended will get HOT and possibly fail.
The LED wants 2.5 V at 25mA - Ohms Law - Voltage = Current * Resistance - E = I * R - 2.5V - 0.025A * R or to re-arrange - R = E / I or R = 2.5V / 0.025A or R = 100 Ohm.
The 82 Ohm resistor will have slightly less voltage drop and slightly higher current and the LED will be brighter..
