What sensor for detecting staircase use?
My use case is pretty simple, I want to detect when someone steps onto the first step of a wooden staircase and turn on an LED light.
My first thought was a piezometer glued to the underside of the first step - but I'm not sure specifically which piezo, whether glue is the best method to bond it to the step, or if there is a different sensor that would be more reliable/easier to implement?
The accuracy doesn't need to be great, it is effectively just a threshold trigger - turn on if a person steps on the step, don't turn on if a cat steps on it.
Is there enough "give" in the step to ensure the piezo is pressed, especially bearing in mind the person may step near the edge of the step where there will be very little give.
What about an ir beam at say knee height, so it would be broken by a human but the cat would pass underneath.
Yeah, that was my concern too. The steps are single kauri pine boards, about 140 years old - they certainly squeak a fair bit when someone walks up them. I'd prefer to keep most of the electronics under the stairs as it avoids having visible wiring.
IR sensor at knee height would work - but then we'd have a sensor and associated wiring sticking on the wall (which is rendered double brick).
Maybe there are commercially available pressure pads with a sort of array of switches inside so that the pad can be as wide as the stair? Could maybe go under the carpet or be disguised as carpeting.
There's also the risk that the walker might not step on every tread of the stairs and not activate your switch unless you have one on each of the first three, say.
Check this out....
PIRs or optical sensors?
Load cells are overkill for simple presence detection.
maybe a RCWL-0516??
I use one to detect when someone walk past on the other side of a concrete wall.
(it triggers when I walk past on the inside too so not perfect...)
But if you place one under the stair facing upward and not walk under the staircase? might work
best of luck.
