What sensor is fast enough to read gyro data?
Hi, I want to get a gyro sensor with the capacity to read at least 65-??? times values in a second, and then save the data into a SD card in a TXT file with those values, Is there any sensor which can do that?
In summary: 60-65 reads in 1 second and store values in a SD card.
Thanks in advance. :D
Yes, most gyro sensors can do that. For example the MPU-6050 with the i2cdevlib uses 100 samples per second.
The normal SD library is not very fast, it is based on a previous version of the sdfat library. The current sdfat library is however a lot faster.
