What sensor/tracking to use?
Hi!
Im going to make visuals on an event. I want the crowd to have the possibility to interact with the visuals through some kind of sensor. My idea is:
To give something I can track to maybe 20 people in the crowd, for them to hold in a hand
Then I want to by tracking their handmovement make drawings in my visuals.
My two criteria for the tracking system is:
  • Have to be something I can "lose". Something inexpensive
  • Something not driven by batteries
    Some ideas:
  • Since most people today have cellphones, maybe find a way to track the gps signal from a cellphone? Any tips?
  • Maybe connect small battery to IR-led to track with camera with IR filter. (not perfect solution since it probably will be lightshow among the audience and since i dont want to use batteries)
  • Color tracking - not ideal since uncertain lightconditions
    Any input welcomed!
thanks
Arduinos do not have the power to process video.
Weedpharma
weedpharma:
Well ... I know that :slight_smile: Im not using Arduino for process video. Im using arduino in this case to take care of inputs from sensors. Im using processing for the graphic parts
Well.....how was I to know that? :((
Give all your information at the beginning so we do not have to guess what you want to do or how you are going to do it.
Weedpharma
My post was primary about sensors and posted in the sensorsforum. So thought it was clear but sorry if it wasnt.
Anyway ... any tips is welcomed ...
maybe there is a way to track the positions of the cell phones in the room by "tracking all the availible wifi connections and collect the coordinates"?
Based on the info provided and many assumptions…
(BTW: no idea of venue size, indoors outdoors although ‘room’ does suggest indoors, 20 in a crowd of 100 or 1000+, spacing, walking sitting or both, resolution/accuracy of movement and/or position?, Do you need coordinates or just movement of hand? Do you need to track movements more than one person simultaneously etc etc etc )
  1. You could write an app for their smartphone to use the sensors on board the phone and send that back in realtime over the internet (or local wifi if available)…
    (cost of writing the app?)
  2. You could do something similar with a pro mini with and xDoF sensor and an NRF24L01+ with 3xAAs
    (circa $10->$20 hardware cost + firmware cost) Simple Bluetooth would work if the venue is not too big.
  3. You could give them relatively powerful IR emitters, which could be tracked by cameras attached to an RPi.
    (If at relatively dark you could just use the lights on modern phones, but then everyone could play along :frowning: ). If indoors both of these should be OK. You would need multiple cameras for 3D movements.
    In fact you could potentially just use cheap IR remotes.
  4. Also check out the nintendo wii IR sensors…many cool projects have been done with them.
FYI: Forget tracking wifi or bluetooth by RSSI…usually fails.
All the above assumes location coordinates are not required and you are only looking for actual hand movements.
Better suggestions might be possible with more detailed info!
You are not going to get GPS data from phones without an app, and even then the privacy concerns will probably kill the idea... Look on the net for disposable LED art projects. These are powered by a small battery and LED, cost a couple of dollars each maybe less.
http://www.lilyleds.com/Products/113/LED-Throwies
If you flashed this using an IR LED:
at 38kHz, you could detect it with a tsop IR detector.
