Chasis: Tamiya Tracked Vehicle Chassis
Motor: Twin Motor Upgrade
Board: Arduino Mega 2560
Mini Servo For Ultrasonic Sensor
Which Motor Shield Should I use, Do I need One?
adruinouno111:
Mini Servo For Ultrasonic SensorWhich Motor Shield Should I use, Do I need One?
The motor(s) operating voltage and maximum current requirement are the two fundamental pieces of information one would need and use to select a compatible motor drive module or shield.
Do you need on? That depends on if you want the arduino to control the motor(s) or not.
Lefty
Which Motor Shields Are Compatible With The Arduino Mega 2560 Board. When I Get Motors I Will Find The Ones Compatible.
adruinouno111:
As I don't own any motor shields I can't answer directly. I would think most would work due to the common shield layout unless the motor shield is using I2C or SPI methods to communicate with the board, in which dase there may be compatibility problems, as the mega1280/2560 chips map such pins differently then the meg8/168/328 based boards.
Lefty
