What SPI mode should I use?
I'm interfacing with a SPI Serial Flash from Microchip and it says the following:
Commands, addresses, or input data are latched on the rising edge of the clock input, while output data is shifted out on the falling edge of the clock input.
What SPI mode should I use in this situation? Also, what is the default SPI bit order on the Arduino?
Thanks, Greg
I would use the default. That is mode 0. See here for more details:
http://gammon.com.au/spi
Here's a post about interfacing flash memory using SPI:
http://www.gammon.com.au/forum/?id=10990
And interfacing with a Microchip device:
http://www.gammon.com.au/forum/?id=10940
In all cases I just used the default mode and bit order.
Here is a post that I made a while back with SPI problems (my lack of understanding being the biggest problem.)
About the 6th or 7th replay could be as beneficial to you as it was to me.
http://arduino.cc/forum/index.php/topic,85553.0.html
