Good morning,
Actually I am working on a GPS/GPRS project. I am a beginer but I got a great result.
My ocde work fine. May be there is some thing to perfect but until now I got the GPS fix in regular schedule.
I also have a code to send the data to a server via HTTP and with AT+ command.
I tested the code separately and it worked fine.
Now I merged the code by adding a function call void sendDATA(){} and when the fix is display, the sebdDATA function follow the GPS fix data.
The problem is when the terminal is ready to lunch the sendDATA code, the module carsh and restarted as if I press the rerset buton. If I comment the sedDATA function it work. If I execute the sendDATA code in a different sketch file, it works.
It like if the memory is full, or if the terminal has too much to read.
Do you have an idea?
Now I am thinking to put my senDATA code into a senDATA.h file to have it has a library.
Do you think it will help?
What is the benefict?
What would you recommand me to create successefuly my first library?
What are the point that I mst'nt miss?
Many thank for your help
Here is me sendDATA code
NewSoftSerial.h
/* FUNCTIONS RELATED TO GPRS WHILE SENDING DATA TO THE SERVER*/
// HOW TO HAVE IT AS A LIBRARAY AND SEND DATA (GPS FIXES) TO A SERVER IN HTTP OT HTTPS
// getMessage is defined outside, but I can have that function here
// cell. is defined outside
// GPRS_ACTIVE and SENDDATA are defined outside but I can remove its
// requests (is a String) is defined outside but I should add it as para,meter in my function sendDATA(requests)
// for eating a single message we expect from the module
// prints out the next message from the module. if it's not the expected value, die
void waitFor(String s) {
String message=getMessage();
if (message != s) {
Serial.print(F("Wait, that's not what we were expecting. We wanted "));
Serial.println("\""+s+"\"");
cellOutputForever();
delay(100); // wait for a tiny bit before sending the next command
// if something goes wrong, abort and just display cell module output so we can see error messages
// this will loop forever
void cellOutputForever() {
Serial.println(F("Looping forever displaying cell module output..."));
while(1) {
if(cell.available()>0) {
Serial.print((char)cell.read());
// keep reading characters until we get char c
void waitForGSM(char c) {
while(1) {
if ((char)cell.read() == c) {
delay(100);
return;
// receive string such as "SOCKSTATUS: 1,1,0102,10,10,0"
// 0 is connection id. 1 is whether connected or not. 2 is status (0104 is connecting, 0102 is connected, others)
// 3 is sent bytes. 4 is acknowledged bytes. 5 is "received data counter"
// THIS FUNCTION WILL check that sent bytes == ack bytes, and return that value
// return 0 if they don't match or if amount of data is 0
int checkSocketString(String s) {
if (socketStringSlice(3,s) == 0)
return 0;
else if (socketStringSlice(3,s) == socketStringSlice(4,s))
return socketStringSlice(3,s);
return 0;
// returns the index of the nth instance of char c in String s
int nthIndexOf(int n, char c, String s) {
int index=0;
for (int i=0; i<=n; i++) {
index = s.indexOf(c,index+1);
return index;
// expects string such as "SOCKSTATUS: 1,1,0102,10,10,0"
// returns nth chunk of data, delimited by commas
int socketStringSlice(int n, String s) {
String slice = s.substring(nthIndexOf(n-1,',',s)+1,nthIndexOf(n,',',s));
char cArray[slice.length()+1];
slice.toCharArray(cArray, sizeof(cArray));
return atoi(cArray);
void sendDATA(){
/* SEND THE DATA TO THE SERVER */
//cell.println("AT+SBAND=6");
#ifdef GPRS_ACTIVE
#ifdef SENDDATA
#ifdef DEBUG
freeRAM();
Serial.println(F("1. Attaching GPRS..."));
#endif
cell.println("AT+CGATT=1");
waitFor("OK");
#ifdef DEBUG
Serial.println(F("2. Setting up PDP Context..."));
#endif
cell.println("AT+CGDCONT=1,\"IP\",\""+apn+"\"");
waitFor("OK");
#ifdef DEBUG
Serial.println(F("3. Activating PDP Context..."));
#endif
cell.println("AT+CGACT=1,1");
waitFor("OK");
#ifdef DEBUG
Serial.println(F("4. Configuring TCP connection to TCP Server..."));
#endif
cell.println("AT+SDATACONF=1,\"TCP\",\""+ip+"\",80");
//cell.println("AT+SDATACONF=1,\"TCP\",\""+ip+"\","+port+"");
waitFor("OK");
#ifdef DEBUG
Serial.println(F("5. Starting TCP Connection..."));
#endif
cell.println("AT+SDATASTART=1,1");
waitFor("OK");
delay(5000); // wait for the socket to connect
// now we'll loop forever, checking the socket status and only breaking when we connect
while (1) {
#ifdef DEBUG
Serial.println(F("6. Checking socket status:"));
#endif
cell.println("AT+SDATASTATUS=1"); // we'll get back SOCKSTATUS and then OK
String sockstat = getMessage();
waitFor("OK");
if (sockstat=="+SOCKSTATUS: 1,0,0104,0,0,0") {
Serial.println(F("Not connected yet. Waiting 1 second and trying again."));
else if (sockstat=="+SOCKSTATUS: 1,1,0102,0,0,0") {
Serial.println(F("Socket connected"));
else {
Serial.println(F("We didn't expect that."));
// we're now connected and can send HTTP packets!
//int packetLength = 26+host.length()+request.length()+useragent.length(); // 26 is size of the non-variable parts of the packet, see SIZE comments below
int packetLength = 26+host.length()+requests.length()+useragent.length();
#ifdef DEBUG
Serial.println(F("7. Sending HTTP packet..."));
#endif
cell.print("AT+SDATATSEND=1,"+String(packetLength)+"\r");
waitForGSM('>'); // wait for GSM module to tell us it's ready to recieve the packet
cell.print(requests+"\r\n"); // SIZE: 2
cell.print("Host: "+host+"\r\n"); // SIZE: 8
cell.print("User-Agent: "+useragent+"\r\n\r\n"); // SIZE: 16
cell.write(26); // ctrl+z character: send the packet
waitFor("OK");
// now we're going to keep checking the socket status forever
// break when the server tells us it acknowledged data
while (1) {
String s = getMessage(); // we want s to contain the SOCKSTATUS message
if (s == "+STCPD:1") // this means server sent data. cool, but we want to see SOCKSTATUS, so let's get next message
s = getMessage();
if (s == "+STCPC:1") // this means socket closed. cool, but we want to see SOCKSTATUS, so let's get next message
s = getMessage();
waitFor("OK");
if (!s.startsWith("+SOCKSTATUS")) {
Serial.println(F("Wait, this isn't the SOCKSTATUS message!"));
cellOutputForever(); // something went wrong
if (checkSocketString(s) == packetLength) // checks that packetLength bytes have been acknowledged by server
break; // we're good!
else {
Serial.println(F("Sent data not yet acknowledged by server, waiting 1 second and checking again."));
#ifdef DEBUG
Serial.println(F(" "));
Serial.println(F("YES! DATA ARE SENT AND ACKNOWLEDGE BY SRERVER!"));
#endif
#endif // END IFDEF DSENDDATA
#endif // END IEF GPRS_ACTIVE
/* **** END SENDING DATA TO THE SERVER */
