what the...? very strange RAM bug.
OK, so I made this little graphing program, witch simply reads anna analoug value and displays it via TV-out. here is the code:
#include <TVout.h>
#include <fontALL.h>
TVout TV;
int value;
void setup()  {
  TV.begin(_PAL,128,72);
  TV.select_font(font8x8);
  TV.println("ready to graph.");
  TV.println();
  TV.println("please enter   1-9 in serial  to start.");
  while(Serial.available()==0)
  TV.clear_screen();
byte ch=Serial.read();
    if(ch >= '0' && ch <= '9')
      value = (value * 10) + (ch - '0');
    }else
TV.println("ERROR:");
TV.println();
TV.println("not a number!");
while(1)
  //hang
value=value*100;//convert
TV.draw_row(71,0,128,WHITE);
TV.draw_column(0,0,72,WHITE);
 int newx=0;
 int newy=0;
 int prevx=newx;
 int prevy=newy;
 prevx=newx;
 prevy=newy;
 newx==analogRead(0);
 newy++;
 Serial.println("X="+newx);
 Serial.println("Y="+newy);
 Serial.println("RAM: "+memoryFree());
 TV.draw_line(prevx,prevy,newx,newy,WHITE);
delay(value);
//RAM debugging:
extern int __bss_end;
extern void *__brkval;
int memoryFree()
  int freeValue;
  if((int)__brkval == 0)
     freeValue = ((int)&freeValue) - ((int)&__bss_end);
    freeValue = ((int)&freeValue) - ((int)__brkval);
  return freeValue;
now, this did not work. after entering the speed via cerial, it goes into the graphing screen and is meant to log the value. it displays the X and Y lines at the bottom and left of the screen, but the actual data line is not present. so, as you can see, I added some debug statements. now here is the weird part. I am receving this in serial:
RAM:
AM:
M:
ready to graph.
eady to graph.
ady to graph.
dy to graph.
y to graph.
 to graph.
to graph.
o graph.
 graph.
graph.
raph.
aph.
ph.
h.
 in serial  to start.
in serial  to start.
n serial  to start.
 serial  to start.
serial  to start.
erial  to start.
rial  to start.
ial  to start.
al  to start.
l  to start.
  to start.
 to start.
to start.
o start.
 start.
start.
tart.
art.
rt.
t.
ERROR:
RROR:
ROR:
OR:
R:
not a number!
ot a number!
t a number!
 a number!
a number!
 number!
number!
umber!
mber!
ber!
er!
r!
C
?ðAlR
ðAlR
ðAlR
AlR
AlR
AlR
AlR
lR
lR
R
R
E
h
È
and so fourth with random junk. what it looks like to me, is it is going trough every RAM bit 1 step at a time, in reverse. witch explains why the sentences of data are incomplete. (it does not look for the start but the end of strings, I know why.) I have tryed to change all strings to TV.printPGM(PSTR("string for program memory here")), but similar occurs. even stranger is that it hangs and does not output the Y or available RAM (put there to see if it was a memory problem(well of course it is, but to see if it was out of memory)). what can I do?
I have an UNO and according to my benchmark program I have 1154 bytes of memory used by TV-out at the current resolution out of 2Ks, so that seems sufficient. but that is without any other vars, just text on the screen.
You should probably not be adding integers to string constants. That doesn't do what you seem to think it does.
Try something like this:
 Serial.print("X=");  Serial.println(newx);
 Serial.print("Y=");  Serial.println(newy);
 Serial.print("RAM: ");  Serial.println(memoryFree());
